Am not getting any sound out of these two packs. The batteries are good, the packs are both switched to +10dB. The channels are correct.
SOURCE: when i first turned my shure sm58a beta wireless
You need to re-sync the receiver with the mic. Refer to your user manual for the procedure.
SOURCE: Shure T2 SM58 intermittent transmit
Two screws on the back of the battery casing, then prise out the battery tray (it's a detachable moulded tray in the mic body) using a small screwdriver in the slot near the power button. Under the threads of the battery cover is screw which holds in the PCB, unscrew this. Take the full mic head off (not just the ball, but an inch further down with the capsule in it), and remove the circlip inside. The PCB then slides out towards the head end of the mic.
SOURCE: shure sm58 just started outputting very low volume
Check your wire connections inside the mic where the xlr cable connects to the mic. Hopefully your mic has never been dropped as this will damage it. The sm58 is pretty much indestructible, so check your cabling that you use, try a different channel.
SOURCE: mic not working
On some mics, one of the lights will NOT turn on unless the battery is low. The mic is the transmitter, so I am not sure what you mean by it not lighting, but the transmitter is lighting?
Make sure the mic's freq. is within the scanned range of the receivers. Often the mics get mixed with other receivers and the resulting pair are incompatible.
The receiver should show if signal is being received. If it is, then the module in the microphone dynamic cartridge MIGHT have been damaged. If it is damaged, it has to be replaced.
