Touch screen don`t work
SOURCE: jvc kw-avx800 divx upgrade
go to ur settings. you will find a divx code. with that code you have to log on to the internet and sign up. with that code you enter it (following the instructions) then you will recieve the update, with that update it will ask you to save it to disc or removable storage device. once saved, plug it into ur jvx deck and it should update automatically.
SOURCE: Connecting a subwoofer to JVC KW AVX800
Hello pmdharan, It sounds like the subwoofer is not turned ON. Go to MENU ITEM > SPEAKER SIZE >SW (subwoofer) and select ON. Hope this helps.
SOURCE: JVC KW-AVX800
hi , those units have the touchscreen conector in the lower side of the screen , it happends lose one or 2 conductive tracks from the flex to the screen it can be fixed with a conductive pen , can check visualy where is the open loop n'd aplly just few conductive ink to restore the circuit ,
