Yes, you can. However, you want to make sure you get a well-made laminate floor. Many laminates are not waterproof and putting them in areas of the house that can get water on teh floor may not be the best idea. You might want to switch to luxury vinyl plank flooring. This product looks like laminate and is more durable. you might also consider luxury vinyl tiles. We have a niche free forum site that goes into great detail on this topic. you can find it here: Best Flooring Forum ' BEST RUG PRICES
Laminate flooring in the bathroom due to the worry of water damage. I would recommend staying away from it in the bathroom. As moisture gets under the planks, they will begin to expand and pop up.
First, you can get the exact visual design that you wanted
and it will cost you considerably less. Second, laminate flooring can be
installed above and below the grade unlike hardwood flooring. Moreover, the
laminate flooring is installed without using any nails or glue which make it
much easier to it yourself. Furthermore, laminate flooring is extremely
durable, easy to maintain and can be replaced easily.
Laminated floors are possible to install over virtually any type of floor you have although over carpets and especially high-pile carpets it is not advised.
Pre-glued laminated floors are easier to install than most other flooring, unless you're experienced and accustomed to working with your hands, you might want to leave this one to the professionals.
Glue-less laminated floors can be installed fast and are
able to be used immediately. Glue laminated floors need to set for 18 to 34
hours before being walked on.
You get an idea on how much laminated floor you will need by measuring the length and the width of the rooms that you plan on installing laminated floor, multiply the length by the width and add 10 percent for installing errors and variation in floor design.
