Question about Refrigerators
The lower zone (for red wine) no longer chills the wine and the LED controls do not function. What do I need to replace to get this unit working as designed?
40 bottle dual zone wine cooler is not functioning properly. The lower zone (for red wine) is not cooling at all. BOTH fans are not operating. Also, the LED controls (located between upper and lower zone/compartments) are dead, they don't show temperature or any reading, so there is no way to adjust the temperature(s) of the compartments. Only the top zone is working and chilling my white wine. Is there a fuse that has blown that is replaceable? How can I get the LED controls to light up and work? How can I get the lower zone fans to work/cool the compartment for red wine?
Posted by Peter Bennett on
Richard Roth
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Feb 06, 2013
  • Peter Bennett Feb 12, 2013
    The unit is a dual compartment duel zone wine cellar by Haier, model # HVTB40DPABS.
4 Related Answers
Anonymous
  • 27 Answers
SOURCE: wine cooler
cheak the machine main on/off switch, cheak the in$out phase line
Posted on Jun 21, 2008
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: Electricity works, unit doesn't cool.
Hi and welcome to FixYa. I am Kelly.
This is a 6 or 8 bottle free-standing wine cooler from what I can tell.
I am not having much luck determining if this is a manual defrost type unit or not. Given the inital sales price now of $79.95 I have to assume it is a manual defrost type.
There are a few things that can cause your problem.
1. PTC relay and KliXon thermal overload assy on the compressor.
2. Run capacitor
3. Temp control
You said the fan does not run so I cab not rule out the temp control.
I can not even find a parts break down of the unit.
With no fan running the very first suspect is the temp control but you can at least listen for a CLICK when you cycle it from off to any other position. If you hear a click I would start looking at compressor start / run parts.
If you have access to your units compressor note the manufacturer, hp if stated (1/8hp etc) and Model number.
Then call or visit your local appliance parts supply store with that information in hand. The will have a PTC relay / KilXon thermal overload AND run capacitor that will fit your unit. I am pretty sure that will get you going again UNLESS you have a broken wire somewhere.
The replacement parts are going to run about 50% of the cost to replace the whole thing.
Thanks for using FixYa!
Kelly
Posted on Feb 19, 2010
Anonymous
SOURCE: Haier wine cellar HVTS18DABB top zone won't cool.
Maybe not the answer for everyone, but I proved it was the fan by removing the back panel, removing the fan and finger guard, then placing a small desktop fan that was the same size as the top-rear fan on the wine fridge. Pumping air directly over the heat sink allowed the unit to attain the temperature set on the front panel. The old fan would either not turn at all, or too slowly to be effective. These fans are junk. Especially after finding articles such as this out in different forums for the same issue. I have the HVTS18DABB model unit and the replacement fan is a simple 120mm square, 25mm deep 12V DC fan. Similar or the same as you see in computer chassis. Found some inexpensive, high CFM, low noise fans from the following site:
http://www.sidewindercomputers.com
Specific fan for my application was the model SY1225SL12SH. Although I did order a second fan that is similar in case the .5amps was too high and I popped a fuse. These fans are inexpensive folks, as long as you aren't afraid to get your hands dirty. Good luck.
http://www.sidewindercomputers.com/sc12slsy110c.html
Here are the details on my order:
Name Code Qty Each Options
Yate Loon 120x25mm D12SH-12 1 5.99
D12SH-12 High Speed -
Black (88 CFM, 40 dBA)
Scythe 120x25mm SY1225SL12SH 1 7.95 Add Black Sleeving = No
SlipStream SY1225SL12SH -
110 CFM
Subtotal 13.94
Shipping 7.02
Tax 0.00
Posted on Aug 16, 2010
Azrael SRL
  • 11800 Answers
SOURCE: I have a Vinotemp VT-12TEDS-2Z Dual Zone
This cooler uses the Peltier effect = the current passing thru a very special resistance provides the cooling. Because of that there are effectively 2 separate electrical circuits inside your cooler:
1, the mains voltage that powers the Peltier element and the cooling fan - controlled by a relay
2. the low voltage that powers the control board and the display - this is the one that failed in your case.
To fix it you will have to open the front cover , access the board and test it: if it gets power then the board itself has failed; if it doesn't then its the power source and you will have to find out why it failed - probably it was damaged when another component failed and you will have to find out which one before putting a new source in.
It's a relatively complicated job that requires a good experience - if you don't have it then call an certified repairman.
Posted on Jan 08, 2011
What is the correct temperature for beer? Or wine. Or pop? Please
Hi Laraine:
Beer:
- If you're British, warm. Canadian, wet. Otherwise, who cares?
Wine:
- white - chilled, red - warm. If you're Canadian, wet.
-Pop - cold, but if you're Canadian, stick to beer and wine so....... Who cares?
Cheers
Jun 06, 2016 | Furniture
N'finity wine cooler
call the repair man if probably needs recharged with freon
Feb 16, 2015 | allavino MWR-1682-BL-C 170 Bottle...
My dual zone wine cooler stopped cooling. Power is good and fan is working.
Fan is wired separately from the cooling unit. you may have a wire corrosion issue. take put the shelves, disassemble the back of the unit from the inside and observe the wiring to see if there are broken or corroded wires/connections. R/R if necessary.
Dec 14, 2014 | Magic Chef Dual Zone Wine and Beverage...
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
Not colling
Check the back to see if the compressor is running or just really hot. If it is not running it could be a thermostat issue, but if it is hot and not running, that means your compressor has problems and will need to be replaced.
Apr 07, 2014 | Whirlpool 22" Dual Zone 38 Bottle Wine...
Wine cooler doesn't cool
I recommend that you maybe add more details to your question so it will be easier for Experts to understand the question and answer it.
Oct 06, 2012 | Kalorik WCL-20629 18 Bottle Dual Zone Wine...
What is a single zone wine cooler?
A single zone wine cooler allows you to store only red/white wine correctly. The cooler has only one temperature control and one space for storing your wines.
Jul 31, 2012 | Furniture
Refrigerators Logo
595 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
