Question about HP LaserJet P3005 Printer
How to connect hp laserjet p3005 to a network or wifi
I would like to know if it is possible to connect printer HP Laserjet to my home wifi.
Posted by Greg on
Rich Varsay
  • 826 Answers
Follow this link ,may be it will help you....http://www.hp.com/global/us/en/wireless/printer-setup-help.html
Posted on Feb 06, 2013
5 Related Answers
Joed911
JDTec
  • 4338 Answers
SOURCE: How to change a fuser
you can download the complete manual here, It is in 2 parts. I have downloaded the manual to my computer. The Fuser replacemant starts on page 101 of the first part of the manual. You may have to copy and paste the link into your browser. Also when you click on part 1 or part 2, select "free user" it will go through a 30 sec clock the give you the option to download. It works.
http://printer1.blogspot.com/2008/04/hp-laserjet-p3005-printer-service-and.html
If you have problems I can email you the 3 pages you need.
Joe
Please remember to rate Techs who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Oct 09, 2008
BobbyR1234
Bobby
  • 173 Answers
SOURCE: HP LaserJet Q2612A printer driver needed
The best place to find drivers for any device is always from the manufacturer's website for the product or hardware device you have. Click here for HP's driver and support website. Another good place to find drivers is drivers.com. You might also want to check out this site for a free driver scan tool here. I would suggest trying HP first, then drivers.com and if still no luck try the other one. I hope you find what you are looking for and found these helpful to fix your problem. If you have any questions or need further assistance please feel free to contact me.
P.S. If you would not mind, could you please rate my help as I would greatly appreciate it. Thanks
Posted on Mar 28, 2009
frankzjm
Frank Zhang
  • 191 Answers
SOURCE: How to replace a pickup roller in Tray 2, HP LaserJet P3005n
please reference here:
https://www.laserpros.com/hp_P3005_tray_2_pickup_assembly.asp
hope you fix it well
Posted on May 13, 2009
Lars-Eirik
  • 65 Answers
SOURCE: hp laserjet p3005 error message 49.4c02 error
Turn the printer off. Remove any jobs i the printercue. restart, and the printer should be OK.
Posted on Aug 03, 2009
Anonymous
SOURCE: how to connect to network printer hp laserjet 2015 PCL5
I cannot connect to hp laserjet 2015 PCL5. wia network...
im using 64 bit windows 7, and tell me that Windows cant find a driver for HP.........i install driver and nothing........
Posted on May 17, 2010
I can not power on my hp laserjet p3005 printer
Try plug the powercord in different outlet.
No luck ? Your powersupply i probably defect and needs to be replaced. Contact your local HP repair-shop and have them repairing your product.
Feb 03, 2014 | HP LaserJet P3005 Printer
Hp laserjet 3005 exchange the formater board then the board is 3005d.the printer is not duplax
Depending on which P3005 model you have I don't suspect there should be a problem. You just won't be able to duplex of course and of course you will have empty connections where the duplex connections would go.
I have interchanged usb formatter only boards with network boards on other HP models and vice-versa.
Nov 05, 2011 | HP LaserJet P3005 Printer
My Hp laserjet p3005 drops offline and cant print, any help
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Sep 06, 2011 | HP LaserJet P3005 Printer
Where can I download the latest Firmware upgrade for the HP LaserJet P3005 printer. I am unable to locate it on the HP site
Doesn't look like there is any firmware updates it would be posted on the site you could check if HP Easy Printer Care Software has any options for firmware upgrades.
Mar 18, 2011 | HP LaserJet P3005 Printer
How do I find the MAC Address for a HP LaserJet P3005 Printer. I am attempting to set the printer up for network use.
Print out the configurationpages and there you'll find the MAC adres.Use the arrow down button to scroll to the informationmenu, scroll down to "print configuration" and press the green button.
Jul 29, 2010 | HP LaserJet P3005 Printer
Error 49A What does this mean?
Hi! I will be glad to assist you. If this is your issue, here are the steps you need to do:
HP LaserJet P3005 Printer Series - Service Error 49.0E00 when Printing PDF Files from Mac 10.5
Issue
A Service Error 49.0E00 message appears while printing PDF files from Mac 10.5 with the EconoMode setting enabled from the printer control panel and using the printing presets with the EconoMode setting disabled.
Solution
Recommended action:
Disable the EconoMode setting from the printer control panel (the default setting is OFF ).
Select printing presets with the EconoMode setting disabled.
Try performing a test print from PDF files in the computer to check for the results.
NOTE: If it is required to use a printing preset with the EconoMode feature turned off, ensure that EconoMode is set to OFF from the printer control panel also.
or you can go to this link:
http://h10061.www1.hp.com/ccsearch/search?ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=1846089&productBigSeriesOid=1846087&spid=1846090&pname=HP+LaserJet+P3005+Printer&opname=HP+LaserJet+P3005+Printer&pname_desc=HP+LaserJet+P3005+Printer&st=1&ptype=commercial&stype=pn&qry=Error+49A&translate=&iqry=&ctflag=&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-007%2Cs-005%2Cs-017%2Cz-001%2Cc-002%2Cc-001&spname=HP+LaserJet+P3005+Printer&cqry=&uqry=&product_line_code=PQ
Oct 05, 2009 | HP LaserJet 3055 All-In-One Printer
HP LaserJet P3005 Printer Logo
479 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
