I doubt it as it was never designed for that kind of input, Component works best on this set and it should have only one HD input for a box marked in the menu as DTV.
The next time it shuts down (I presume the green power light goes off) do the self check this model has, on front of set press and hold both the menu and input buttons for at least five seconds and release both.
Power light will blink a 2 digit error code like : 1 blink, 2 blink and repeat it several times.
1,2 is no error detected but there are other codes.
try to go to the ps3 settings then go to video output settings , then go to hdmi and it should go black for a min. i didnt think it was working for mine then i unpluged it and there was a big diffrence but it should work
Hello, asnowman here.
I had to reply to this post, as the other would not let me.
Your question:
Comment posted on Oct 26, 2009
Thank you for your help, do you know what board this is on? signal, main, or power?
Your televsion is the 73411, and I think that your convergence IC's are on the center board, (called the power board, even though it doesn't have the flyback on it), if they are not they are on the signal board. You can't miss them they are attached to a very large aluminum heat sink and the IC's are very large as well.
I hope that this answers your questions.
If you need further assistance please comment to this post and I will try to help you further. Thanks for using FixYa asnowman
no, the set only has anolog inputs there is no DVI or HDMI input to the set. DVI and HDMI are a digital pathway where as Y,Pb,Pr are high scan anolog. DVI carries only digital video and must be accompanied by an audio wire. HDMI carries both digital audio and video. this set was made before a standard of digital pathways were approved.
