Question about Dell PowerEdge 1600SC Server
Dell poweredge 1600sc w/ ATI Mach64 w/ Windows 7 Ultimate highest video mode is 24 bit true color
I went to the Dell Support web site and there is no graphic driver for windows 7 Ultimate and I can not play certain games that require 32 bit color resolution setting and I have an old A10 bios with limited settings.
Posted by Frederick Goehringer on
Dayton Computer
  • 1,578 Answers
Bios too old and the 32 Bit system is inadequate to manage the function desired.
Posted on Jan 29, 2014
5 Related Answers
Anonymous
SOURCE: Poweredge 1600sc cant see other 4 drives
you may have a raid 5 setup. you should be able to confirm this within the raid bios (ctrl+m). if all disks are part of the raid 5 array i believe you will only see this as one virtual disk. a raid 5 array will put the data across all the disks along with parity information. if one disk fails then when you add a replacment disk this parity is used to rebuild your array.
Posted on Aug 28, 2008
Anonymous
SOURCE: install windows xp pro
Hi
My is working , i have same dell server 1600 , i download the driver from LSI website here is the link
http://lsi.com/storage_home/products_home/host_bus_adapters/scsi_hbas/lsiu320/index.html?remote=1&locale=EN
you just need u320 scsi driver for server 1600sc
download XP driver 32 bit it will work
victor
Posted on Aug 29, 2008
Anonymous
  • 53 Answers
SOURCE: corruption exists!System halted?
you have a bad memory stick.
Posted on Jun 03, 2009
Rob C
  • 547 Answers
SOURCE: How long do Dell Poweredge 1600Sc Servers last? We...
If it's still working, there's no "requirement" to replace it, but Dell will probably not support it after a certain age.
Servers in general will fail on either power supplies or hard disks. Both of those are well past the average lifespan (what's called the "mean time between failure", or mtbf for the parts)
If you don't have an IT person or department, the simplest approach is to ask yourself this question:
"What is the cost to my business if this computer dies tomorrow?"
Then figure out how much it would be to replace the computer (purchase + install and configure)
If the replacement cost is less than the business-impact cost, then you should replace this 7-year-old box.
Posted on May 22, 2010
SOURCE: how to install windows7 64 bit dell poweredge
Maybe, It doesn't work because the driver you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))julyallan01_28.jpg
Posted on Dec 06, 2010
How to install windows7 64 bit dell poweredge 1600sc ?
Sep 23, 2010 | Dell PowerEdge 1600SC Server
How long do Dell Poweredge 1600Sc Servers last? We've had ours for 7 yrs. For our office and have been told it's required to get a new one.
May 20, 2010 | Dell PowerEdge 1600SC Server
PowerEdge 1600SC long beep and hang
check the Cmos battery. or levae pluged in over night and then check setup setting you battery went dead
Oct 12, 2009 | Dell PowerEdge 1600SC Server
Dell 1600SC Server - trying to install a video card
try repeatadely pressing delete on startup with the monitor cable attached to your onboard graphics socket but keep the new graphics card in. then you should go into the bios. change the graphics setting to your graphics car and then save and reboot. it should now work from your new graphics card
Jun 18, 2009 | Dell PowerEdge 1600SC Server
My Dell powerEdge 1600SC Server Fail.....
Sounds like you're running Windows Server 2003 and want to run a backup utility.
Fortunately, this OS ships with a built-in backup utility called we call "ntbackup."
You can launch this program from Start -> Run, or you can find it in Start -> Accessories -> System Tools -> Backup.
Jan 03, 2009 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1600sc server is running
What operating system is the server using? What roles is the server doing (DNS/DHCP/DC/Exchange/etc). If it's a Windows 2003 SBS box, you're supposed to be able to run upto about 75 users. I would never run more than 30 users on an SBS box (and it'd have to be a very high spec). You may consdier bringing another server to do an aditional role (file/print) and leave the primary to be an SBS box
Oct 10, 2008 | Dell PowerEdge 1600SC Server
Install windows xp pro
Hi
victor
Jul 04, 2008 | Dell PowerEdge 1600SC Server
1600sc second CPU
Hi
Yes, some systems (newer PowerEdge Servers, generally 6/7th Generation and above) have onboard VRMs.
1600sc is a 6th gen PowerEdge (with Simple Computing). I can checked and be absolute certain from within Dell. I'm on VAC until Saturday.
In the meantime, check the PRC model and revision and ensure that they match. Given that a single PRC POST/Boots, try upgrading (if not already) the system BIOS to latest revision.
If the PRC model/revision does match and you have the latest BIOS version, also if the VRMs are not needed, then from the Troubleshooting you have already done, we may conclude that the PRC 2 slot is faulty.
I will confirm the VRM query on Saturday.
PowerEdge 1600SC, BIOS A12 Update Package for Microsoft Windows - http://ftp.us.dell.com/bios/PE1600SC-BIOS-WIN-A12.exe
PowerEdge 1600SC, BIOS A12 Floppy Update Package - http://ftp.us.dell.com/bios/PE1600SC-BIOSA12.exe
Mike
May 14, 2008 | Dell PowerEdge 1600SC Server
No Video Signal on 1600sc
Disconnect from the network and all other accessories, and power up the system, this might be due to a faulty device attached to the system, eg: when you connect a usb faulty device the boot takes very long time, sometime it does not boot up.
Dec 30, 2007 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1600SC Server Logo
244 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
