Question about Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor for 56J Frame
I bought a new hayward 1hp pool pump motor, i am having trouble disconnecting the old but working impeller housing and impeller to put on new motor. Need to take off quick, any suggestion.
5 Related Answers
john224
John Prohaska
  • 1378 Answers
SOURCE: Hayward Max-Flo pump: Need to separate pump from motor
Remove the back cover from the motor, lock the shaft in place, thread off the impeller.
Posted on Jun 14, 2009
protek480
Craig Butler
  • 1730 Answers
SOURCE: My pool pump is 2 months old. It is a Hayward 1hp
The capacitor is probably bad. It's under the cover on the side of the motor, Take a look and smell it. A motor shop has them, or Grainger
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 03, 2009
jharwell668
Jessica Harwell
  • 640 Answers
SOURCE: we have aEC-65 hayward pool filter with a 1HP
I believe that this particular model is a DE pool filter. Is that correct? If you are operating with a media other than DE, let me know. Assuming that you ARE using DE:
1. You DE could be coated to the maximum with pool dirt algae, etc. To correc this problem, you need to bump the filter.
2. You could have an overcharge of DE. To remedy,
Bump-Drain-Recharge.
3. Restriction in return line caused by small
eyeball fitting. To correct, change to a larger sized fitting.
4. You could have a partial closed valve on a return line. You will just need to open the valve.
5. Make sure that your pump strainer basket and pool skimmer basket are not clogged.
6. Make sure that your pump impeller valves are not clogged.
Posted on May 26, 2010
MOTORWIZJ
Jay Finke
  • 1389 Answers
SOURCE: Hello , I have a 5yr old pool complete with
ALWAYS FREE.. SO IT SEEMS THAT YOUR NOT GETTING AIR, THESE BLOWERS HAVE FOAM IN THEM AND CAN ,AFTER A FEW YEARS GET CRISPY AND BREAK UP AND PLUG THE AIR PUMPS SUCTION PORT. THE FOAM IS USED AS A AIR FILTER AND A NOISE REDUCER , WHEN THESE BLOWERS GO BAD 90% OF THEM CAN'T BE REPAIRED ! = JUNK.. TO SEE IF YOU HAVE A RESTRICTION IN YOUR LINE OR LINES ,USE A SHOP VAC TO **** AND BLOW THE LINES IN AND OUT.. THESE BLOWERS ARE HELD IN USUALLY WITH ONE SCREW AND ARE EASY TO REPLACE ONE MORE CHECK 4 YA IS, THERE MIGHT BE A CHECK VALVE INLINE ON THE BLOWER , IT MAY BE BAD . BEST WAY TO CHECK IS TURN THE BLOWER ON FIRST , THEN TURN THE WATER PUMP ON.. HEY IF'N I WAS OF HELP GIVE ME A REVIEW OR A THUMB.. JAY YOUR LOCAL POOL PUMP WHISPERER IN FLORIDA
Posted on Nov 16, 2010
Testimonial: "Thank you -- the 2hp motor provides air induction and bubbles. There is no foam to break off. I did blow system out , still the same. Will keep lookin"
john224
John Prohaska
  • 1378 Answers
SOURCE: HAYWARD SUPER PUMP 1HP. ABOUT
Thank you for posting your question here on Fixya.com.
It could be the pump is bound up but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
Start with the capacitor if one is present. Use a digital multi-meter (DMM), preferably with a capacitor setting, or an analog meter set for Ohms. With an analog, you should see the needle deflect as if testing a closed circuit then it will slowly drop to 0 if the capacitor is good. If it doesn't move or moves and stays to the side showing a closed circuit the capacitor is bad. If you notice a burn hole near the terminals on the end of the capacitor do not bother to test it. If you do not have access to a meter you can try grounding the posts together with a screwdriver to see if they arc although it is not a very reliable test method. Be sure you are holding on to an insulated handle for the tool you use to short the terminals together or you can get a good poke.
Next check the internal stationary start switch for continuity thru the contacts. Bent or burned up points and arms can cause a startup failure...you may need a new part if yours is more than bent out of position.
Finally check the winding for grounds and shorts...if you find any it is most likely time for a new motor.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage. If you wish to continue to try to repair it yourself please comment with any questions you have as you work thru the pump and motor.
If this answer does not fix your problem, please comment with additional details or contact me thru our site at www.arrowpools.net prior to rating the answer; I'll do what I can to help. Positive feedback is appreciated once your problem is solved!
John
Posted on May 21, 2011
Will a smith 1hp pump fit in place of a hayward 1hp
as long as the frame size matches i.e. 56J in this case then you should have NO issue with changing the motor mfg.
US Parts Center
Aug 18, 2011 | Hayward 2HP Pool Pump Motor A O Smith...
MY PRESSURE IS ONLY A 5 AND IS USUALLY 18-20 WHAT COULD BE THE PROBLEM. WE BACKFLUSED AND DID WHAT THE BOOK SAID BUT DID NOT WORK
Check your impeller. Remove the pump motor from the housing to inspect the impeller. Be prepared to replace the seal.
Let me know what you find.
Thanks for using FixYa.com
Jul 25, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
Remove impellersp1592
Assuming power is disconnected and pump freed from hoses,:
Pull the clip out from inside the basket housing. The entire housing comes off.
Open the cover at the power end, and
Put a large screwdriver into the slot on the end of the shaft.
Holding screwdriver in one hand unscrew the impeller by hand with the other.
If it is too hard, you will need a special tool that won't damage the impeller.
Jun 20, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
Ihave a hayward 1hp inground pool pump and can not get the impellar off
you will need to hold the motor shaft at the back of the motor with either a 7/16 open end wrench, or either armature tool. You can then use a closed face impeller wrench to remove it. Make sure if there is a screw in the center of the impeller to remove it by turning clockwise.
Sep 06, 2010 | Hayward 1 Hp Max - Flo Swimming Pool Pump
HOW TO GET IMPLER OFF TO REPLACE THE SEAL ASSY
The impeller unscrews counter clockwise. I assume you already have the motor disconnected from the pump housing? If you need to hold the motor, it will depend on what kind of motor you have. Some motors have a wrench flat on the rear shaft of the motor if you remove the rear cover. It usually takes a 1/2" open end wrench. Be careful not to bump into the centrufugal switch assembly. Another trick is to use an impact wrench IN REVERSE ONLY it will often break it loose even though the motor spins. Only use it to remove it not to re-install impeller.
Aug 13, 2010 | Hayward 1HP Precision Inground Pool Pump
How do I get old motor off pump to install my new motor?
The front of the wet end must be removed to access the impeller. Then remove the rear electrical covering to expose the rear end of the motor shaft. Look closely at the shaft. It has two flat sides. A 12mm open face wrench will fit onto the shaft. Lock the shaft in place with the wrench and unscrew the impeller. The rear housing behind the impeller pops off to reveal four 9/16 bolts. Remove them and the motor is free. Reverse the process with the new motor.
Apr 22, 2010 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Replace pool motor
First you'll need to take the outer 6 bolts off the pump housing and that will allow you to remove the impeller and impeller housing with the motor. Then you can remove all the impeller parts and get to the bolts that hold your motor to the housing....
When you get the impeller and the housing free, check to see if your motor will turn... alot of times the motors get jammed because the pump sucks debris and jams in the impeller.... you may be able to still use your motor...worth a try...
K
Aug 05, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
Jul 03, 2009 | Hayward Power Flo Lx 1 Hp Pool Pump Sp1580
Leak between seal plate and pump/strainer housing
The pump seal is leaking and needs replacing and requires removing four 3/8 bolts (9/16) wrench and removing the motor then the diffuser to get to the impeller and seal . A 7/16 wrench holds the rear motor shaft behind the springs and impeller spins off to reveal the seal which has two parts one on the impeller with a spring and one in the seal plate is white ceramic/ porcelan whatever they use. Part number is an SPX1600KA on super pumps and 1500KA wassome above grounds. When replacing do not touch the mating white and black surfaces with your fingers.
May 25, 2009 | Hayward 1HP Super Pump II Inground Pool...
Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor  for 56J Frame Logo
180 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
