SOURCE: Canon L80 fax
here is the free manual
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=e6acb34012ce93f0a6c1b191aa41892c&q=Canon+L80
SOURCE: memory full on canon fax-tr177
Try unplugging the power cord for 10 seconds. Do you have ink / paper?
SOURCE: how do you clear documents received in memory?
sir, its simple if you want to clear all the docs received. but its difficult if u just want one doc to vanish. To clear everything just remove power cord and communication media for 5 minutes. Hope this solves you problem.
SOURCE: Memory Full Canon i-sensys Fax L120
try this
press "menu" and then "#" button, go to service mode. Select the "clear data function". and select "memory clear"
SOURCE: Fax job in memory that will not clear. Canon 2050P
1)Open the One-Touch Speed Dialing panel, then press 'Memory Reference'.
2)Use up or down arrow to select 4.DELETE DOCUMENT. 3)Press 'Set'. 4)Use up or down arrow to select the TX/RX number you want to delete. [you can check the documents stored in memory by pressing < or > ] 5)Press 'Set'. 6)Press * to delete or # to cancel deleting. 7)Press 'Stop' to return to standby mode.
Reference page 8-8 in Canon LC2050P user guide.
