Car Audio & Video Logo
Question about Car Audio & Video
Radio code for citroen nemo 59
I need the radio code for my citroen nemo
3 Related Answers
Anonymous
  • 284 Answers
SOURCE: citroen audio manual
botton 1 is the first digit, button 2 is the 2nd and so on after all 4 done press 6
Posted on Dec 19, 2009
xxxxxx xxx
  • 5067 Answers
SOURCE: Citroen/Blaupunkt radio unlocked but won't stop beeping
VIN coded radio.
Radio will require coding to your car`s management+security system.
Contact your Citroen Dealer or Radio Decoding Business
Posted on May 29, 2010
xxxxxx xxx
  • 5067 Answers
SOURCE: Radio code missing
Try code 6 2 2 4
Posted on Jun 08, 2010
2answers
Radio code citroen xsara 1997
try www.reliable-store.com you'll get help there
1helpful
What compatible transmission can I use for replacement?
PLease check with a salvage yard they have cross reference manuals for this very thing.
Tyre pressure fo Citroen nemo
should be on the driver side door or in owner s manuel
Reset oil change light on citeron nemo 2011
Reset oil light after service... that is very important. And don't skip the oil change either.
1-turn on the ignition key,
2-press the gas pedal and hold it,
3-press the brake pedal 7 times without relesing the gas pedal,
4-keep pressing the gas pedal for 60sec.
5-Release the gas pedal and turn of the ignition key,
6- Wait for 60sec.
Then turn on the ignition key and start the engine. Check if the service/oil change light turned off.
That's it. Worked on my 2011 nemo van.
Cant open fuel filler cap on citroen nemo
Sounds like a vapor lock. disconnect a hose on the filler neck if you can or try to relieve pressure in the tank.
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
