The Same is happening with me its might be Windows 7 issue, try to update the driver automatically through device manager, if it will not work ask to your tech support...
first right click my computer in the desktop then properties then hardware then device manager then expand the audio,vedio and game controller see wether the driver is installed properly if not installed it will show yellow question mark the reload the correct drives from the cd which you recived with your computer install the audio software and restart the system then in the taskbar you will see the speaker icon right click them click adjust audio properties in volume move the slisders to full on uncheck the mute then restart your computer
i got digi 001 running on windows 7...
i left my xp on hard disk while installing win 7. it kept xp on folder windows.old folder. in control panel i saw digi as multimedia adapter wich system couldn't recognice. hit "change settings" -> driver -> update driver
used my old windows to search for driver. it found "Dalvin.sys" driver for adapter. installed that. after that windows recogniced digi 001.
downloaded "digidesign asio 6.11" driver installer for win-xp and ran it.
and bingo - it works!
in every step windows was complaining and asking do i want to do this. just yeah'd everything. as i just had a clean install of win 7 i just thought whatta heck i can install everything again if it would not work, but it did.
so in a nut shell:
1: install Dalvin.sys in control panel for digi 001
2: run digidesign asio 6.11 driver installer for win-xp
for me it worked but i absolutely take no responsibility if you mess your system with this! at least reaper got a sound out of it. i haven't tried to record anything yet. but asio settings seemed to work as they used to do in xp.
If you are using a desktop comupter, you will need any 6-pin to 6-pin connection. If you are using a laptop, you will need any 6-pin to 4-pin connection.
