Water line are checked and clear. Water pipes froze the other night and ice has not made since.
SOURCE: My new refrigerator's ice maker and water dispenser doesnt work
Since this is a brand new unit, I wouldn't waste the time or money troubleshooting it yourself; contact the place you purchased it from and exchange it.
Its probably way too late, but ours was delivered / came with the water pipe being crushed at the front right at the bottom of the fridge/freezer. So I would check the full length of this small diameter pipe.
SOURCE: We have a LG bottom
Make sure water is gettig to solenoid vale on back. If so make sure screen is not plugged and solnoid is real opening. May need to test coil on valve. If it is not opening or froze off Ice marker will cycle several times a day as it is temp actuated.
SOURCE: LG SXS Refrigerator LSC26905 ice maker
I was able to order the ice tray myself and install it in the fridge - it's not hard. I ordered from one of the parts sellers linked to at the LG website, not those listed in other posts here.
Here's how to replace the tray:
You need to remove the tray dumping mechanism to do this.
That's it. You can press that test button on the underside of the motor. This will dump the tray and immediately refill it with water so you can observe if everything is working.
SOURCE: LG 26930tt side by side refrigerator water leaking
Make sure the unit is not all iced up, try to defrost it and then retry, turn off the ice maker and water supply before defrosting. Put a thermoter in the freezer to check temp.
