Question about Power Acoustik PTID-8300NR Car Video Player
No sound all wires hook up but no sound?
Posted by matt on
julie_shenna
    New Friend:
    Problem Solver:
  • 6 Answers
You could have blown the speaker output or there is a menu to turn speakers on
Posted on Feb 05, 2013
No sound out of my speakers model 5269480
on your amp under the back seat their are 2 plugs the one on the left which is the smaller of the 2 there is a Tan wire w/Orange stripe on it hook the remote wire from stereo plug which will be blue w/white stripe to that wire so it will power-up your amp...Bottom line, no amp = no sound,unless you figure what wires are the speaker wires and hook directly to your stereo plug............Its an easy fix
Oct 13, 2012 | 1994 Jeep Grand Cherokee
Installation BOSS 9990 POWER **** IS ON BUT NO SOUND
recheck all wire make sure the yellow wire and red wire is hook up right
Jul 03, 2012 | Boss BV9990 Car Video Player
XO VIson DVD 7" works fine but when it is turned
sounds like you might have the wire that is always supposed to have power hooked to a switched power source
is it possible you hooked up power wires wrong
sounds like switched wire is hooked to battery and battery connection is hooked to switched source
only other option would be if ground is hooked incorrectly it should be hooked diretly to clean non painted metallic spot on cars body
if you need more help give me more details and i will try to help more
Good luck
Mar 13, 2011 | Panasonic XO-1515 XOVision Car DVD/CD/MP3...
No sound on atari 800? tv works I don't have the 300 ohm screws so i hooked the wires on the switch box to the box itself only way I got a picture. then hooked the cable wire to box then computer. Games...
Go back to square 1. Unhook the wires from the switch box. Get the 300 ohm screws and hook up the wires the normal way. Try changing the sound card.
Aug 18, 2009 | Computers & Internet
No sound to speakers hooked to RCA jacks.
you have the wires mixed up. the positive wire is hooked into the negative, rechech your wiring
Apr 13, 2009 | Dual XDMR-7700 CD Player
Stereo hook up no sound
After all connections are completed correctly - Press the RESET button. The RESET button on the housing must be activated with either a ballpoint pen or similar pointed object. The RESET button is to be activated for the following reasons:
• Initial installation of the unit after all wiring is completed.
• Some the function buttons do not operate.
• Error symbol appears on the display.
Jul 10, 2008 | Virtual Reality Sound VR3 CD Player w/ USB...
All speakers arent working
press mode and effect keys on remote.
ht50 screen shows 2, 3 and 5 speakers
depending on mode.
Jan 14, 2008 | Samsung HT-X50 System
Power Acoustik PTID-8300NR Car Video Player Logo
Top Power Acoustik Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
