Question about Plumbing
I have a Jado Oriental bath faucet chrome/gold with crystal knobs. I need a replacement Crystal knob but it's no longer sold. Any ideas where I can find it?
Elizabeth Heyman
    New Friend:
If it isn't too late, I have a single crystal knob also. Couldn't find another when one of mine broke, so I bought two in the chrome finish. Let me know if you're interested in my (unbroken!) crystal knob.
Posted on Nov 18, 2016
Becca s
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
Elizabeth do you still by chance have this one handle? I broke one of ours and can’t find a replacement ! You would be a life saver! - Becca MN contact me [email protected]
Msn.com
Posted on Jun 30, 2020
1 Related Answer
Anonymous
  • 11 Answers
SOURCE: Compatible replacement handles for Moen Garden Tub faucet
I dont know if moen made chrome handles for that valve back then. If they did then they will probably be lever handles but they wont turn correctly unless you remove the cartridges and turn them. Iwould suggest probably replacing the whole unit.
Posted on May 07, 2009
I have a JADO Oriental faucet with separately installed knob handles. No set screw. How do I go about removing them?
Use a block of wood and a couple flat head screwdrivers
carefully pry up on the faucet handles using the wood as leverage. But do not force them, heat up with a hair drier first before removing.
Jan 11, 2018 | Jado Plumbing
Can't take a bath!
The diverter can become clogged with mineral deposits. The handle will have to be removed to gain access to the diverter. The diverter can then be disassembled as necessary to determine what needs to be done to free it up.
Jan 17, 2014 | Home
Replace handle with different style
One of those big-box home suppliers might have something you can use or can order something. Likewise, a plumbing supplier could have just what you are looking for. Moen is a common brand which makes compatibility more likely
Feb 09, 2013 | Moen T999P Chateau Two-Handle Low Arc...
Dirty white pierre cardin watch
Mild soap and very little water on a clean rag for the band. Scratches? on the crystal it means new crystal. On the case there may not be a solution depending on whether it is plated or solid metal(Stainless, gold, etc). If sold then it could be buffed. Doesn't sound as if it is a very practical watch.
Oct 06, 2012 | Watches
How do I remove the water knobs (handles) on 4530 LHP?
at the bend in the faucet handle there is a hole that has a set screw in it
May 09, 2011 | Delta 4530-NCLHP Innovations Bath Faucet,...
Defective Jado classic master bath products
sounds to me as though the problem might be coming from where the drain and pop-up rod meet,..you know how there is usually some little parts i.e.; o-ring, teflon bushings, etc. that HAVE TO BE put in in order,? check that stuff out and if it fixes problem, what looked like bad a spout might not be anymore,......
Oct 30, 2009 | Jado NEW CLASSIC ROMAN TUB SET WITH HAND...
Can't pull up the knob that diverts water from bath to shower
you can try taking it apart, starting with the handle, then the cover, im sure it can be fixed.
Aug 10, 2009 | Plumbing
Apr 20, 2009 | Moen Chateau, Two-Handle Garden Tub Faucet...
Eljer lavatory faucet will not shut off. Chrome knob is stuck.
If you are trying to remove the handle you need a handle removal tool sold at all hardware stores
Nov 10, 2008 | Plumbing
Plumbing Logo
186 people viewed this question
Top Plumbing Experts
Bill Johnson
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
