Question about Samsung R540 Laptop
When I close the lid, it shuts down after a while. How can I rectify this? I used to close the lid at night and finding it still on the following morning. PLEASE help
I can be contacted via my e-mail address: [email protected] I appreciate any form of help
Posted by anthony_peyp on
Rafique Mannasaheb
    Sergeant:
  • Samsung Expert
  • 406 Answers
Dear first check the battery and power settings (power options in control panel)
Als o make sure that battery is performing welll.
This may be due to settings only.
Posted on Mar 09, 2013
When I close my lid, pc crashes
Laptop shuts down / crashes after closing lid - used to hibernate ...
en.community.dell.com/support-forums/laptop/f/3518/t/19496556
Dell
Mar 13, 2013 - 16 posts - ‎7 authors
Now shuts down after closing the lid after several hours - at least .... My computer crashes when it goes to sleep regardless of the lid's position. E7440 - sleep Issues and display issues - General ...
Apr 17, 2014
crash after sleep/close lid - General Hardware - Laptop ...
Nov 21, 2012
More results from en.community.dell.com
Laptop Sometimes Crashes When Close Lid to Sleep - Windows
Dec 01, 2015 | ASUS Computers & Internet
Cq60 shut down and restarts itself
Common if backup, windows update, or defrag is scheduled to run at night. Other scheduled operations may use the restart function as well.
Feb 18, 2014 | Compaq Presario CQ60-204NR Notebook
Laptop will not shut of after closing the lid
In Windows XP, Open Control Panel, Power Options, set to High Performance, set Sleep and Hibernate to no/never, set what to do when lid is closed. Use this procedure: http://windows.microsoft.com/en-us/windows-xp/help/setup/configure-power-management It's a good idea to Shut down at Start Menu and unplug when not in use to prevent damage due to power surges, and IF the battery malfunctions, prevent a fire hazzard.
Feb 25, 2013 | Dell Inspiron 1501 PC Notebook
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
What's your problem?where is switch located that shuts off NV52 when lid closes
go to control panel /appearence personisation /system security go downtoo power optionsedit plan settings (change when comp goes to sleep /change advanced power settingsbox will open power options work way down to power buttons and lid open that up + on battrey open lid close action you will see do nothing open that up and press shut down
that will shut down youre comp when lid closes
Jul 16, 2012 | Gateway NV5215u Notebook
I have connected a LCD screen to my laptop however, when I close the lid on my laptop the LCD screen shuts down too. Can you please tell me how to fix this. Thank you Robin
You need to open the power settings. This will be under the control panel or show up as an icon by the clock.
You just need to find the selection for when you close the lid. On my toshiba it says something like "When I close the lid do the following:" What you need to do is set it to do nothing and that should fix your problem.
Aug 28, 2010 | Computers & Internet
Laptop will not power on. When laptop lid was
System board has failed you will have to replace it.
Feb 23, 2010 | Compaq Presario 700 470024-192 Notebook
Oven doesn't work, but stove does
Once I opened the lid, the oven reset itself. I then closed the lid and it went off again. I did this again (lifting the lid), and the oven again reset it self. I fiddled with the wiring to the stoves and the bundle of wires, and when i closed the lid again, it did not shut down. It has continued to work.
Dec 13, 2009 | Kenmore Ovens
Keeps on filling and wont drain
please follow the steps which i give to find and rectify the mistake (1) First check the wash load/laundry. If it is unevenly distributed in the tub making it unequal, rearrange it, close the lid again.
(2) Make sure your washer is leveled and you have filled sufficient water in the tub for that size of wash load/laundry. Insufficient water can make imbalance.
(3) Make sure the power cord/cable is plugged into the working electrical wall socket.
(4) It is better to check the appropriate circuit breakers or fuse of the fuse box and reset if necessary.
(5) Inspect the drain hoses and remove any bends. Inspect the drain system, too - if it's clogged.
(6) Then close the washer lid and pull out the knob to start it. For your safety, the washer will not spin unless the door is closed.
(7) Excessive foam can also cause this problem. If you find it to be the solution, rewash the clothes with plain water. For future, ensure use of correct amount of detergent with low-foam.
(8) It is possible that the lid switch, that prevents the washer from spinning when the lid is open, could be malfunctioning. If that happens, a built-in mechanism – brakes will be applied and washer will stop washer operations until the lid switch is repaired/replaced.
Jun 13, 2009 | Washing Machines
Close lid of laptop without shutting down system
You have to configure what laptop do when the lod is closed . go to Control Panel , Power Options , Advanced . In this tab you will see an option " When I close the lid " and a drop down menu just choose do nothing and press ok . It will not shut down your laptop when lid is closed .
If you like my solution do vote for me
Farhan
www.senseapplied.com
Jan 05, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Samsung R540 Laptop Logo
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
