Nikon Used N6006 AF 35mm SLR Autofocus Camera Body Logo
A
Anonymous Posted on Feb 05, 2013
Error: FEE on Nikon AF N6006 film camera with Nikon lenses.
I do not have the resources to go digital. So I'll stay with these great pro level film cameras. When Error Code FEE appears in the window the camera is stuck where it was. What causes it and how do I fix this? Thanks, Bob
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Nikon Master 102,366 Answers
  • Posted on May 09, 2014
Nikon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443236
Points
622693
Turn the aperture ring on the lens to its smallest setting (largest f/number). You can control the aperture from the camera body, the same way as with a lens without an aperture ring.
5 Related Answers
Anonymous
  • 667 Answers
  • Posted on Jan 12, 2008
SOURCE: Nikon N60 SLR camera
It is more likely that the tab has separated from the plate it slides on. The spring is attached to the plate with the tab sticking out from it. I have repaired these in the past by boring a small hole in the backside of the tab and use a screw to re-attach it.
Anonymous
  • 667 Answers
  • Posted on Jan 17, 2008
SOURCE: Nikon N60 35mm camera error code FEE
Check your lens aperture ring setting. It must be set on the highest number I.E. f16,f22,f32..
Brian Mathews
  • 20 Answers
  • Posted on Feb 05, 2009
SOURCE: location of rewind pin for nikon n6006 film camera
There is a safety switch to prevent accidental operation.  Hold the camera like you are taking a photo.  Rotate the camera down so the lense is pointing towards the floor and you are now looking at the bottom of the camera.  On the right is a small button.  In the middle is a slide switch with an arrow pointing to the left.  You need to hold in the button on the right while sliding the switch to the left.
Anonymous
  • 302 Answers
  • Posted on Oct 11, 2009
SOURCE: camera film door will not latch. The door latch
Can it be repaired? It needs a new latch piece. Maybe a new door, if its all one piece.
I do not own one so not sure about that model. Look at the door hinge. If a small lever sticks out of the hinge, it may be easily removed and replaced with a new door. otherwise you need to remove the bottom plate of the camera to replace the door. Be very careful doing so as things could pop out when you open it.
You could also send it in to a repair shop, where they will also clean, lubricate and adjust it before returning.
Is it worth it? Only you can answer that. You might be able to pickup a used one on Ebay, so you have a source of parts.
If you have no reason to keep that particular camera, replace it with a newer Nikon, so you can keep using your flash and lenses.
  • 102366 Answers
  • Posted on Nov 15, 2010
SOURCE: I'm looking to buy a
Yes, as long as it's not a DX lens. DX lenses are designed for the smaller image area of some digital cameras and will cause vignetting (dark corners) on a 35mm camera. The vibration reduction feature of VR lenses won't work, but won't cause any problems.
DX lenses will fit and work, but as mentioned above, you will get dark corners.
Testimonial: "Thanks!!"
What lens can I use the the Nikon N6006 35 mm SLR Camera?
The Nikon N6006 will use just about any Nikon F-mount lens made in the past 55 years. About the only exceptions are some rare (and very expensive) fisheye lenses and the newer DX lenses specifically designed for digital cameras.
3helpful
Problems using Nikkor AF 35-70mm F3.3-4.5 with Nikon D80?
The sensor on the D80 is smaller than a piece of 35mm film. This means the camera will only use the center portion of the image cast by the lens. This reduces the angle of view, effectively increasing the focal length. The 35-70mm will give you an angle of view similar to a 52-105mm lens on a film camera. Likewise the 70-210mm lens will give you an angle of view similar to a 105-315mm lens.
I have a 35mm film Nikon camera with Quantaray NF AF Lenses. I'd like to find an affordable digital camera that I can still use these lenses, any suggestions ?
Those lenses will fit on every Nikon digital SLR. However, the autofocus will only work on cameras with an autofocus motor, the the AF will not work on the D40, D40x, D60, D3000, D3100, D5000, and D5100. Note that this is just the focusing: if you're willing to focus manually then those lenses will work perfectly well on those cameras.
Due to the smaller image sensor of most digital cameras, the lenses will act as if they were about 1.5 times longer. Thus a 50mm lens on a digital camera will give about the same field of view as a 75mm lens would on a film camera. This applies to all Nikon dSLRs except for the D3 family and the D700, which behave in this respect like a 35mm film camera.
You have to decide what's affordable for you, balancing such factors as weight, ease-of-use, and of course cost.
You can see the current Nikon lineup at
http://www.nikonusa.com/Nikon-Products/Digital-SLR-Cameras/index.page
3helpful
What is the " fEE
You need to turn the aperture ring on the lens to its smallest aperture (largest f/number) and lock it. You can control the aperture from the camera body, the same way as on lenses without an aperture ring.
1helpful
USE A NIKON F-801S GET THE MESSAGE ERROR fEE 8 and a bip bip bip sound the film is new/ battery full / use a lense Tamron af
Turn the aperture ring on the lens to its smallest opening (largest f/number). If the ring has a lock, lock it in place. You can control the aperture from the camera, the same was as on a lens without an aperture ring.,
Mar 21, 2011 • Cameras
3answers
Nikon Lenses
They will fit but will work only in manual mode
11helpful
Location of rewind pin for nikon n6006 film camera
Compatability issue
Curious, Have you tried another AF lens on the N55?
2answers
FEE display contant
defective focus lens circuitry, you need pro fix.
Top Nikon Photography Experts
Tony Parsons
Tony Parsons
Pallikonda Nisha
Level 1 Expert
Are you a Nikon Photography Expert? Answer questions, earn points and help others
