Question about Precor Exercise & Fitness
Precor 9.45 err 26 - Precor Exercise & Fitness
Sportsmith LLC
  • Precor Master
  • 918 Answers
Precor Error Code 26 Error Code: 26 Manufacturer: Precor
Model: All Models
Error Description: Error 26, Motor Pulse Width Incorrect - Observation of the speed sensor signal and verification the signal from the speed sensor is appropriate for the requested speed. If an incorrect or erratic speed sensor signal is detected the error appears. Possible Reason:
  1. The line of sight between the speed sensor and the speed sensor target is obstructed.
  2. Incorrect gap between the speed sensor and the speed sensor target.
  3. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  4. Damaged speed sensor target.
Recommended Action:
  1. Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
  2. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  3. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  4. Inspect the speed sensor target for any scratches or tears that could cause incorrect readings. Replace the speed sensor target if necessary.
Posted on Aug 07, 2014
Error 22-23-26
Precor Error Code 23
Error Code: 23 Manufacturer: Precor
Model: All Models
Error Description: Error 23, Motor Pulses Missing after Start Up - Indication that the speed sensor signal was lost while the unit was in operation. Possible Reason:
  4. Intermittent connection of speed sensor or drive motor wiring.
  5. Badly worn drive motor brushes not able to make proper contact with drive motor commutator.
  6. Faulty lower PCA.
  7. Faulty interconnect cable between upper and lower PCA.
  8. Faulty upper PCA.
Recommended Action:
  4. Test all wiring and wire connections of the speed sensor and drive motor. Replace or repair necessary wire connections or wiring.
  5. Inspect and replace drive motor brushes if necessary.
  6. Determine if the lower PCA is bad by swapping with a known good lower PCA.
  7. Determine if the interconnect cable is bad by swapping with a know good cable.
  8. Determine if the upper PCA is bad by swapping with a know good upper PCA.
Precor Error Code 22
Error Code: 22 Manufacturer: Precor
Model: All Models
Error Description: Error 22, No Motor Pulses at Start Up - Error indicates that the display has sent a command for the drive motor to start, however, the speed sensor has not returned the signal acknowledging that the drive motor has started. Possible Reason:
  2. Badly worn drive motor brushes.
  3. Incorrect gap between the speed sensor and the speed sensor target.
  4. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  5. Inoperative speed sensor.
Recommended Action:
  2. Bady worn drive motor brushes cannot make proper contact with the motor commutator, therefore the drive motor will not start when voltage is applied. Inspect and replace drive motor brushes if necessary.
  3. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  4. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  5. An inoperative speed sensor will allow the drive motor to start and run briefly before the error appears. If able to access the speed sensor wiring, measure the DC voltage between the speed sensor leads. Two of the leads will always read about 5 VDC. Two will toggle between 0 and 5 VDC as you slowly turn the speed sensor target. If both measurements are not seen, the speed sensor needs replaced. Some units have the speed sensor mounted on the lower PCA and the lower PCA needs replaced.
Model: All Models
Recommended Action:
Precor Error Code 22 Precor Error Code 23 Precor Error Code 26
May 13, 2014 | Precor C964 Treadmill
Codigo de error
List of Error Codes for Precor Fitness Equipment
Error Code List for Precor Fitness Equipment
Feb 05, 2014 | Precor Exercise & Fitness
9.31 precor error 26 and loud noise
Model: All Models
Recommended Action:
Jan 25, 2014 | Dmm Vision Fitness T9500 Treadmill
Precor treadmill err26
Model: All Models
Recommended Action:
Dec 16, 2013 | Exercise & Fitness
Precor Treadmill 9.21si Error Code 26, what does it mean
Model: All Models
Recommended Action:
Sep 07, 2012 | Precor Treadmill 9.21 9.21s 9.25 9.21si...
Speed error 26
Model: All Models
Recommended Action:
May 18, 2011 | Precor 923 LowImpact Treadmill
What does Err26 mean?
Model: All Models
Recommended Action:
Jan 20, 2011 | Precor C956 Treadmill with Cardio Theater...
Received err 42 on my Precor EFX 5.21s - what does it mean?
Precor Error Code 42 Error Code: 42 Manufacturer: Precor
Model: All Models
Error Description: Error 42, Lift Position Value Out of Range. Error 42 is displayed when the lift position reported by the lift position potentiometer is found to be outside its set limits.
If an Error 42 has occurred, it is important to know the physical position of the lift when the error occurred. It is possible the lift is physically out of range or jammed. In this case, the Error 42 is a secondary symptom and the issue should be approached as an Error 40. Possible Reason:
  1. Bad or intermittent connection in the lift motor controller.
  2. The lift motor requires calibration.
  3. The lift motor potentiometer is bad.
  4. The lower PCA to upper PCA cable is bad.
  5. The lower PCA is bad.
  6. The upper PCA is bad.
Recommended Action:
  1. Intermittent connections can be difficult to locate. If the Error 42 condition is intermittent, a connection issue is probably the cause. This is definitely true if the Error 42 occurred while the lift was within its normal physical range. Inspect the lift potentiometer connector and repair connection if necessary. If the intermittent connection cannot be found or corrected, replace the lift motor. A lift calibration number of 0 or 255 indicates an open or shorted potentiometer connection. This means the problem could be anywhere between the lift motor and the upper PCA. Typically it can be identified and tracked using an ohmmeter.
  2. Using the appropriate service manual for the unit being tested, refer to the lift calibration procedure. If the information in the service manual doesn't match the lift position/physical lift position of the unit, recalibrate the lift motor. [Something caused the lift motor to be out of calibration. Investigate for cause and correct. Simply recalibrating the lift motor will not solve the problem.]
  3. If the lift calibration number is not 0 or 255 and does not change when the lift motor turns, replace the lift motor.
  4. Check continuity of the interconnect cable or swap with a known good interconnect cable to verify if cable is bad.
  5. Swap the lower PCA with a known good lower PCA to verify if the lower PCA is bad.
  6. Swap the upper PCA with a know good upper PCA to verify if the upper PCA is bad.
Lift Position Value Out of Range Precor Error 42
Dec 28, 2010 | Precor EFX 546i Elliptical Version 4
Maytag A511 has worked faithfully for 26 years.
Either the engine or the drum bearing are worn out and the rotor/drum is touching the stator/tub. It's normal wear and since replacement parts are no longer fabricated i think it's time to buy a new one.
Jan 30, 2010 | Washing Machines
Precor 9.25i treadmill running backwards.
The power leads Black/red will determine the direction that the motor will turn. If the leads have been switched to the wrong terminals at the lower PCA it will run backwards even if the black and red line up when the motor is plugged in. Check to see if the power cable on the lower board is in the right configuration. I've seen the terminals get switched when a new lower board is installed.
Oct 07, 2009 | Precor Exercise & Fitness
Exercise & Fitness Logo
160 people viewed this question
Top Precor Exercise & Fitness Experts
NOEL
NOEL
daf62757
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
