The hose from the drain valve to the pump is squised
If the tub is full of water you need to empty it. A shop vac with the paper filter removed works good. The drain hose is naturally squishy. Likely there is an object like a sock covering the drain hole in the outer tub. If it's jambed tight enough the back pressure from the pump would collapse the hose. If you remove the hose with water in the tub you will make a huge mess when you remove the sock.
Can't really say more because the mod # you provided isn't correct. Not sure what's wrong, i've tried several combinations but no luck. Perhaps you could recheck it. Make sure it's the model number from the machine.
SOURCE: Whirlpool won't spin at high speed
Sounds like you may have lost your basket drive and clutch assembly. This is a pretty involved job to replace for sure, and requires you to remove the inner basket, drop the transmission, etc. Does the unit make any wierd noises, like popping or grinding? Does it agitate ok in wash? I would bet almost for sure that its that basket drive and attached sub-pack thats went bad. If you want to try and tackle this yourself, let me know, and will get you directions to do so. Good Luck!!!!
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
SOURCE: my cabrio top load washer leaks from underneath
there is the main tub seal that could be leaking and it is between the tub and transmission.
SOURCE: whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
SOURCE: Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
