Cars & Trucks Logo
Anonymous Posted on Feb 05, 2013
Audi a8-replaced battery---trunk lid button and gas door release won't work
  • Sam Rustin
    Sam Rustin May 12, 2015
    cannt open trunk lid
A
Anonymous
Sounds like a blown fuse. Check your fuse panel.
5 Related Answers
Anonymous
  • Posted on Aug 19, 2008
SOURCE: i can't open the lid
I had a similar problem with my TT Roadster and it was a problem with my central locking system, it temporarily disengaged after a minor incident with the rain while my top was down. Anyway for me it was simply a matter of time before the system reengaged it's self it took maybe a week or so, but to get around the problem, behind your passenger seat there is a storage compartment, pull the lever in the storage compartment to open the trunk, once in the trunk on the left sidewall of the trunk there is a seamless square open that square and there is a black pulley in there, pull on that and your gas tank should open. I hope this help.
Anonymous
  • Posted on Mar 29, 2009
SOURCE: trunk release and fuel door release buttons do not work
i just bot mazda millenia and i can't find trunk release???!!!!
Anonymous
  • 290 Answers
  • Posted on Jun 08, 2009
SOURCE: Chevy Impala 2007 trunk lid release
Fold down rear seat and climb in the trunk....there is a manual release at the center of the trunk lid. (mandated by the government to kids don't get trapped in the trunk).
Anonymous
  • 31 Answers
  • Posted on Nov 23, 2009
SOURCE: 2001 audi tt -- trunk release and gas cap release don't work
Hi, yes there is. To release the trunk - look on the centre console, just rearward of the front seats and you will notice a separate rectangular section in the plastic, if you lift this out you will find a cable release for the trunk underneath. To open the fuel filler cap manually, look inside the car just behind the rear light on the same side as the fuel filler and you will notice a flap in the interior trim, which is to allow access to the rear lamp. Open this and then looking towards the top you should see a loop of orange plastic - pull this towards the rear of the car to release the fuel filler.
Hope that helps Matt..
tuyen bui
  • 1025 Answers
  • Posted on Feb 27, 2010
SOURCE: My gas cap and trunk wont open. I need gas.
check the fuses, if you can get into the trunk with the key then there should be a cable or some short to pull to open the gas cap door
2answers
2008 Cadillac CTS push button to open trunk sometimes works
Do you know anything about automotive electronic's ? The trunk release is controlled by electronic control modules . Having the vehicle check for DTC'S - diagnostic trouble code's should be the first step in the diagnostic procedure . Then reading how it work's !
Factory service repair info.
Rear Compartment Lid Release System Components
• Body control module (BCM)
• Remote control door lock receiver
• Interior rear compartment lid release switch
• Exterior rear compartment lid release switch
• Rear compartment lid release actuator
• Trunk release relay
Rear Compartment Lid Release Operation
The interior rear compartment lid release switch receives a signal from the driver door switch assembly (DDSA). When the interior rear compartment lid release switch is activated, the signal circuit is pulled to ground. The DDSA interprets this and sends a GMLAN serial data message to the body control module (BCM) requesting the rear compartment lid be released. The BCM responds by applying battery voltage to the trunk release relay control circuit which energizes the TRUNK RELES relay. The trunk release relay is supplied with battery voltage at all times. With the relay coil energized, the relay switch contacts close allowing battery voltage to flow to the rear compartment lid release actuator causing the rear compartment lid to release. The rear compartment lid release actuator is permanently grounded at G402.
The trunk release relay is located in the rear fuse box located under the back seat.
I replaced the battery in my 2006 audi a8-- now trunk button on drivers door not working--an mmi screen and radio works for 1 min. then off Help!
I suggest you try one of those instant download manuals. My nephew bought one for me when my car broke and we could fix it all by ourselves with the manual costing $10. This website reliable-store.com is very good for this.
?Try it.
I have a 2004 G35 coupe and the gas door won't open even though all doors are unlocked
there is a release threw the trunk check the latch after you open it
Trunk won't open
Lower the back seat and crawl into the trunk and see what the latch is doing when you activate the key fob. the trunk lid will have to be open to enable any repairs. Also an emergency release cable is probably visible (yellow handle) inside the trunk and will Open the trunk lid.
20helpful
5answers
My gas cap and trunk wont open. I need gas. Te button on the console won't release the gas cap to open or the trunk. Audi TT 2002.
Take your key and go to the drivers door, make sure the door is unlocked by pulling on the handle, open and close the door. Insert the key and "lock" the door, double check that it is locked by pulling on the handle. Insert the key and "un-lock" the door, use the handle to open the door and now press the fuel door key and it should open, same for trunk release button.
Audi's are a strange breed, sometimes you just need to "re-set" some stuff. But in the future if you lock the car with the key, the fob will unlock the car but the three buttons in the console will not work, the fob will function correctly.
I hope this helps.
4helpful
2answers
THE BUTTON IN THE CONSOLE TO OPEN THE GAS CAP AND THE TRUNK WONT WORK AND I CANT PUT GAS INTO THE CAR!!!! IS THERE ANOTHER WAY TO OPEN THE GAS COVER AND THE TRUNK???
I can't promise it, but in my 99 A4 there is a release cable in the trunk. I have to pull the trunk carpeting away on the side where the gas filler door is, and there's a red cable there that can be used as a manual release. I imagine your TT has one as well - look in the hatch on the side with the gas door, and pull the lining back - you'll probably have a release cable as well.
I have a 2000 Audi TT Quattro. Never had a problem
I wouldn't be surprised if those are ran off vacuum, Check the vwvortex.com
1helpful
2answers
2005 audi a8 trunk + upgrades for ipod integration
I had exact same problem, but what I found out was a three step solution to the problem.
1) The trunk lock above the trunk lid tself - sometimes looses coiling retention for the lock to work properly, which in effect does not properly lock wrap around the pull down electronic unit located in the body of the car/trunk that catches and pull the trunk lid down SOLUTION: check and make sure lock is works properly. you cab check by opening trunk and locking it with remote key, then pry the lock with a screw driver to see if it unlocks or stays locked
2) The motor catching unit in the body of the car/trunk that catches the lid and draws it down can be off balance (sitting too low to catch the lock (upper trunk lid with lock) to pull it down and stay locked. Have a mechanic - Audi preferrably, check the positon and allignment to adjust it, so it can catch trunk lid and lock to stay locked. HOPE THIS HELPS!
Top Audi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Audi Expert? Answer questions, earn points and help others
