Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
I can cancel the error or print any documents
Turn off the printer and unplug it. Open the top access panel. Inside on the left you will see three round, white gears. Rotate the gear closest to the front back and forth with your finger. If any scraps of paper appear near the rollers, remove them. Close the top access panel. Plug in and start the printer. This worked for a Kodak ESP 3.2.
Posted on May 23, 2014
SOURCE: error code 3820
try the baack of the printer. open it up from the back
Posted on Jan 28, 2009
SOURCE: ESP 7 paper jam error
I had the same problem, but after pressing the OK button when the paper jam came up again I pressed the CANCEL button and was able to print my document. See if that works for you too.
Posted on Apr 12, 2009
SOURCE: Kodak ESP-3 Printer Red Flashing Light
Couple of things.
1. Look inside the printer by the print head. On one side you should see a felt pad of some sort. Make sure this has not come loose. If it has, it can block the path of the print head and will read paper jam. I have seen this mostly with the ESP 5, but I suppose the same could happen with the 3.
2. This way is kind of long but will clear a lot of problems. Open the top of the printer and remove both cartridges and the print head. Unplug the power supply and close the printer. Wait about 30 seconds. Now plug the power back in and wait until the printer stops moving inside. Open the printer and instal just the print head. Unplug and wait 30 seconds. Repeat this procedure with installing the black, then the color. Make sure you unplug for 30 seconds and wait for the internal parts to stop moving between each step. his should fix everything. It has worked for me several times. These really are a decent printer, just a little glitchy sometimes.
3. Make sure a paper has not gotten wadded up and is hidden inside to the left or right of the print head. I have seen this twice in the ESP 3.
Hope this helps.
Posted on Apr 18, 2009
SOURCE: Paper jam in a Kodak ESP- Printer. please note spam number below
i had the printer jam issue when there wasnt a real printer jam.
if you push the print cartidges off to the right, then reach in and push down on the cleaning head that is located on the left on the inside, it pops back down into place and voila, printer jam error message fixed.
Posted on Jul 04, 2009
SOURCE: Printer says 'Unable to detect paper width'
The paper tray has some "fingers" that detect the paper.
Remove the paper and tap the sensors a few times to make sure they are not stuck.
Use lots of mamper, not just one sheet so that there is enough weight to press down on the sensors.
Perhaps it is Earth's gravity that is malfunctioning today :)
Posted on Sep 28, 2009
Oct 19, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Sep 13, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Mar 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Feb 11, 2011 | Office Equipment & Supplies
Jan 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Sep 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Jun 26, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Apr 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Mar 30, 2009 | Kodak ESP 5 Printer
Mar 19, 2009 | Kodak ESP 5 Printer
477 people viewed this question
