Computers & Internet Logo
A
Anonymous Posted on Apr 05, 2017
HP G71-349WM Laptop Boot up Problems
I tried creating a recovery CD for Windows 7 from my other computer but it will not run it, or doesn't seem to. Problem I am having when I turn it on it gives HP invent screen with ESC to enter setup then goes to Windows Recovery Error screen with an option to launch startup repair (recommended) or start normally. Neither work. At one point I was getting a F30 error, hard disk can't be found. when system tries to repair it just goes to a blue screen with what appears to be rays on the screen and just hangs there. Any suggestions would be greatly appreciated as I have an assignment due this Friday and I need to get access to my Access. Thank you.
Larry Ng
Level 3:
Top Expert:
  • HP Master 14,606 Answers
  • Posted on Apr 05, 2017
Larry Ng
HP Master
Level 3:
Top Expert:
Answers
14606
Questions
0
Helped
3280275
Points
66651
There are many LEVELS of OS repair modes.
one is startup files bad, and fix that.
others are refresh.
and last full install.
the HP site covers how to do all that. hp.com
HDD not found is usual just that. bad HDD.
ever listen to one, if silent its DEAD, HDD, not SSDs.
One can remove the HDD, and put it in a eSATA enclosure
and plug it in to any PC modern has eSata, and see if data can be recovered. this is best way 1. or just plug it in to a good system.
Best is Desktop as those can have up to 8 drives installed ,
like my ASUS has. (actually more on mine)
That covers the topic DATA, recovery, 101.
now the cure.
buy a new SSD and then do a fresh install with HP media kit
then copy data from old drive, (if not dead) to new drive.
SOP, standard op. procedures. all.
Windows scans the HDD< for the DRIVER busy line to be not busy
if the drive is dead , it can set this line (all do dead) to true,.
busy forever, (aka READY) and is NOT ready.
when THE OS sees it in that logic state, it can not access it at all.
all it can do in that state is see name of HDD and model.
if super dead, it reads nothing... no Pnp DATA, zero.
and that is a totally dead drive.
one way to prove this is put the HDD in another system.
or run a live linux boot CD and see , yup its dead
or run linux partition tools, yup dead.
or windows 10 PE, boot CD
links to all that are here.
http://pcdied.com/
3 Related Answers
Anonymous
  • 157 Answers
  • Posted on Jan 05, 2009
SOURCE: Can't 'Launch Startup Repair' when Vista boots on Evesham Laptop
when you restart try to press F11 while booting..check
Anonymous
  • 85 Answers
  • Posted on Aug 09, 2009
SOURCE: I cannot get passed the Windows Error Recovery
You need to have the Windows disk in when you select the Repair option. If you are getting a bluescreen consistently, there is a chance it may require a complete windows reinstall or new hardware (depending on your bluescreen information).
Check out this link for troubleshooting help on your specific error message: http://www.maximumpc.com/article/features/blue_screen_survival_guide
Anonymous
  • 61 Answers
  • Posted on Dec 08, 2010
SOURCE: when i boot the system
it seems ur operating system has gone corrupt. Reformatting will solve ur problem.
HP G71-349WM Notebook Problem Starting Up
remove your hard drive put it into another laptop: when you boot the other computer; if the same problem reappears replace the hard drive
tip
4 Proven Techniques to Reset HP Windows 7 password
<span>Forgot HP Windows 7 password? Don't be scared. You can follow these four proven techniques below to<span> </span><b><a href="http://www.passwordunlocker.com/knowledge/reset-windows-7-password.html">reset Windows 7 password</a></b><span> </span>on your own. Certainly, these four HP password reset methods will work in all versions of Windows 7/Vista/ XP and Server 2000/2003/2008.<br /> Technique 1: Reset HP Windows 7 password with Windows Password Reset DiskThis is an easy-to-use method to<span> </span><b>reset HP Windows 7 password</b>, however you need created a disk before<span> </span><a href="http://www.passwordunlocker.com/knowledge/forgot-windows-7-password.html">forgot HP Windows 7 password</a><span> </span>. And the HP Windows 7 password reset disk will only work for the account that have created another ones.<br />To create a password reset disk, you can log on HP PC and enter User Accounts by clicking Start button, Control Panel, User and Family Safety, and User Accounts. Then you can click Create a password reset disk on the left pane (Just as shown on the below picture). A password reset disk wizard will come up, and then you can follow it to<span> </span><b>create a Windows 7 password reset disk</b><span> </span>for your HP PC.<br />When you forgot HP Windows 7 password , your need boot computer to enter Windows logon screen. You'll view the reset password option when you type an wrong password on the logon screen and press Enter. Click on the option and the password reset wizard will pop up to guide you to reset HP Windows 7 password.<br /> Technique 2: Reset HP Windows 7 password with Windows Password HintWhenever you create or change Windows password, there will be an opportunity to type a password hint to prevent forgetting password. When type a wrong password, you will see the password hint be displayed to remind you what login password is. This is the easiest way to reset your<b><span> </span>forgotten windows 7 password</b><span> </span>for HP.<br /> Technique 3: Reset HP Windows 7 password with Windows System Recovery OptionsApart from Create a password reset disk and password hint, the OS Recovery Options can also help you to<span> </span><b>reset HP Windows 7 password</b>. Apart from Windows installation disc or the recovery options provided by your HP PC manufacturer to access the System Recovery Options. You also can create a system repair disc by yourself.<br /> <ul> <li>1. Input the word of" system repair disc" into the search box in the Start menu and press Enter.</li> <li>2. Insert a CD/DVD into the optical drive and hit Create disc.</li></ul>This guide will help to create your HP PC system repair disc. Hence, if you want to reset HP Windows 7 password by this technique, please insert the system repair disc into the optical drive and reboot the PC via this disc. And then choose the System Recovery option that will displayed on the prompt list of Windows installation.<br /> Technique 4: Reset HP Windows 7 password with Windows Password UnlockerIf those three methods that I mentioned above can't help you out. Maybe you need try this proven Windows password recovery tool named<span> </span><b>Windows Password Unlocker<span> </span></b>which can reset any windows password safely and instantly.<br /> <ul> <li>1. Download<span> </span><a href="http://www.passwordunlocker.com/windows-password-recovery.html"><b>Windows Password Unlocker</b></a><span> </span>and install it in any unlocked computer.</li> <li>2. Create a bootable CD/DVD or USB flash drive with the software.</li> <li>3. Set CD-ROM or USB device as the first boot device in BIOS for your PC.</li> <li>4. Boot your lock PC from the created CD/DVD or USB flash drive and then<span> </span><b>reset HP Windows 7 password</b>.</li></ul>Are you relaxed on HP Windows 7 password reset? Next time, you can do it yourself if meet with the similar issue.<br /></span>
on Apr 02, 2011 • Computers & Internet
Forgotten log in password
Which system do you use?
On windows xp, try this:
Boot computer and press Ctrl+Alt+Delete twice when you See Windows welcome screen / login screen. It'll show classic login box. Now type "Administrator" (without quotes) in username field and leave password field blank, press Enter and you should be able to login Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
If that doesn't or you use windows 7 or vista, try this:
1. Enter a computer that can link to Internet. Download Windows Password Recovery Tool 3.0 and install the software on that computer.
2. Run the software and create windows password reset disk by follow the instructions.
3. Eject the created CD/DVD and insert it into the locked computer.
4. Reboot the locked computer (it's necessary for you to change your locked computer's BIOS setting to make it boot from CD drive) and then follow the instructions to reset your password.
5. Now login Windows and set a new password.
Resource: http://www.windowspasswordsrecovery.com
2helpful
2answers
Reset administrator password hp 6735s
On Windows XP, try this:
If that doesn't or you use Windows 7 or Vista, try this:
1. Enter a computer that can link to Internet. Download "Windows Password Reset " from http://www.windowspasswordreset.net and install the software on that computer.
4. Reboot the locked computer (it's necessary for you to change your locked computer's BIOS setting to make it boot from CD drive) and then follow the instructions to reset Windows password.
11helpful
5answers
How to reset hp probook 4310s embeded security password
If your hp computer is installed with Windows 7, following the video to learn how to reset hp computer security password with Windows 7 Password Genius
https://www.youtube.com/watch?v=I5HzG7fb-Wg
If your hp computer is installed with Windows 8, and the password is your only admin password, refer to hp computer Windows 8 admin password reset.
I have an Acer TravelMate 4500 512Mb Ram an 80GB HDD, which doesn't run the operating system boot after bios boot. when I swich on it comes up a bios boot and after that the laptop screen's becomes...
1. Remove or Unplug any recently added hardware.
2. Remove and replace the battery.
3. Press and hold the power button for 7-10 secs to power ON the computer.
4. Try booting to windows Operating System in Safe Mode. (Press F8 key as soon as you restart).
5. Check if the Hard Disk is detected and listed with its capacity of 80GB in BIOS. (Press F2 as soon as you restart).
6. Reset BIOS to default values.
7. If computer boots to windows in Safe Mode, then perform a system restore to an earlier date.
8. Install any updates available for BIOS.
9. If Hard disk is listed in BIOS, perform system recovery using the recovery partition or the recovery discs.
10. If Hard disk is not listed in BIOS, contact any nearest service center to get the computer serviced.
1helpful
2answers
Hi i have a porbolem with my hp pavilion dv5000 so i wanna reformat it and i dont know why
To reformat your HP machine, you need the recovery disks...This article tells you how to create them....Note...they can only be created ONCE from your machine.....so make sure you do it correctly:
http://www.pctechbytes.com/hp/hp-recovery-cd-creation
Next.... BACK UP your data...and TEST it.....make sure your data is working on your backup media....formatting the drive will erase all your data and start over from a fresh copy of Windows.
After that you need to boot your PC from the recovery disk (if it doesn't ask you to boot from the CD you will need to hit F10 key at your HP splash screen to enter the system BIOS. Find the boot order setting and change it so the CD/DVD drive is on top)
After you successfully boot from the DVD, you can pretty much follow the on screen instructions. The following page has more information on reinstalling Windows: http://windows.microsoft.com/en-US/windows/help/install-reinstall-uninstall
Good Luck...be careful, but don't be afraid :) as long as you have good backups you should be all good.
4helpful
4answers
How can i find or reset my user password of my Hp cq40 running in windows7 ultimate.? please help me i need the data
I presume this is a standalone PC and not on a network, if so you could purchase software to recover your Windows password from this website. http://www.recoverwindowspassword.com/
You use this software to create a boot disc, then restart the computer booting from this and it goes into a little applicaiton where you can reset/delete the windows passwords. I used it on my son's XP operating system successfully.
Just read through the website information fully so you understand what is involved before you do it commit and purchase it. You need to be able to boot the PC from the disc so must have a DVD/CD drive connected and be familar with changing BIOS settings so you can boot from the CD location rather than the HDD.
If that last sentance sounded like lefthanded budgie then take it to a computer tech and get them to do it for you, will cost a little more but you'll get the password reset.
16helpful
9answers
I forgot my windows vista password. I dont have any rebootable CD... can you help me how to fix this problem. I am using this on HP pavilion DV6 laptop. I dont have any administrator.
Well, by relying on this password recovery software, you can easily reset HP laptop Administrator login password easily. Fully compatible with Windows 7, Vista and XP etc operation system, supporting both 32-bit and 64-bit. Note: do not easily use your MS Windows recovery or boot CD as it may erase all data.
24helpful
8answers
Forgot password to hp laptop how do i reset it.
I don't know what OS your HP laptop is installed with.
If it is Windows 8, Windows Password Hint, PIN code, Microsoft account can be used to login HP laptop. After logon successfully, change, recover or reset Windows 8 password is available.
If it is Windows 7, Password hint or another administrator account may help you. But if you don't have all of these, try password reset disk. Create it before Windows 8 locked or with Windows 8 Password Recovery tool is OK.
Besides these, Chntpw USB disk also works for Windows 7/Vista etc.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
