Question about ZEEPAD MID Android Tablet 7 Inch WiFi
I am unable to unlock my new Zeepad. It keeps turning off.
It says it is fully charged. It goes on when I press the power button. The time and date come up incorrect, of course. It is locked. It says to press the power lightly to unlock but nothing happens except that it goes off. It goes off even when I don't press the power button. It is almost impossible to read the tiny manual which came with the Zeepad.
Posted by sunsethill on
Henry David
    New Friend:
    Problem Solver:
  • 5 Answers
I think you should return to manufacturer , cause if the zeepad came that way it's their problem
Posted on Sep 29, 2017
3 Related Answers
Michael Green
  • 3799 Answers
SOURCE: I just bought the new android zeepad and I'm wondering what kind of internet service I can get for it. Wifi isn't always available
Buy a mobile broadband dongle. You will then have the advantage of 3G internet access. These dongles are readily available in mobile phone shops.
Posted on Feb 27, 2013
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: zeepad
Your tablet maybe faulty. I suggest you take it back to the shop where you purchased it for a warranty replacement or repair. If you try to fix it yourself you may void your warranty.
Posted on May 21, 2013
ruderunner_2
Jim Rude
SOURCE: how can i unlock my zeepad 7.0 tablet
how can i unlock the screen. i charged the Bat for six hours and held down the power button but the screen shows locked
Posted on Jan 04, 2014
How do i factory reset my digiland tablet
here is a step by step I found :)
1) Power off the tablet. 2) Press and hold the Volume-Down and Power button simultaneously. 3) It displayed a menu in Korean/Chinese (?). 4) Scroll down (using the Volume-Down button) to the SIXTH menu choice. 5) Press the Power button to select. This will start the factory reset process
Sep 13, 2014 | Tablets & eReaders
Www curtisint com
You can try this if you can get it to come up. Wipe and reformat the tablet.
Make sure tablet is fully charged.
Hold the volume up button and the power on button down at the same time.
You might have to press the power button repeatedly while holding the volume up button down.
A menu will come up. Selections of the menu are available by pressing the power button up or down. Select wipe and format.
It will go through the format process and then select reboot.
Hold the volume down button and power button at the same time. That will get you to the starmenu and the WiFi connection. Follow the screen instructions. If that doesn't work your only option is to return it or send it to Curtis for repairs. Don't buy another one. This is my second unit. Very unstable operating system. Mine keeps going off and I have to reboot frequently. Hope you are still under warranty.
Aug 22, 2014 | Proscan 10.1-Inch Internet Tablet,...
Why won't my samsung galaxy tablet will not switch on
If tablet is fully charged, you can try the followiing. Plug in charger a d press and hold power button on tablet. What this does is a little little GI bug your car a jump start, it bypasses the need for tablet to use just internal battery and may do the job. If not, get some electronic switch cleaner, spray around the power button and press power button a few times, this will clear any dust particles that could be affecting the contact. If neither of these work then may be time to have tablet opened up and checked.
Jul 28, 2014 | Samsung Galaxy Tab Tablet PC
Why will a samsung galaxy 2 tablet not charge?
first go to a mobile shop ask hif it it is the problem of battry or some hardware problem inside the tab and also check the charger weather it works or not
Jul 24, 2014 | Samsung Galaxy Tab 2
New tablet just purchased fully charged it then pressed power button as instructed but nothing happens, black screen ???
have you tried pressing and holding the power button for a few second?
also try and charge it before turning it on.
Mar 12, 2014 | Leader Impression 7 Tablet
Unit will not turn on
Press the power button down for 10aeconds, then release and try to turn on again.
Jan 17, 2014 | Microsoft Surface RT
My galaxy tablet will not turn on and or charge
hold the power button down for 10-15 seconds to force a power off. When turning back on, hold the power button down until you either feel it vibrate or something comes up on the screen.
Jan 13, 2014 | Samsung 7 in. Galaxy Tab 3, 8GB...
Nextbook tablet locked forget pattern how can I reset my whole tablet
With the tablet fully charged and switched off (not just in standby) hold the volume up button then press the power button to switch it on....all the time keep holding the vol up button. This should then give you the recovery menu, select 'delete cache' option. This will also delete all saved documents data and apps so be warned. There maybe ways to do it without losing all your data by using special developer tools via a laptop plugged into it's USB, but i suspect you'll need professinal help to do that.
Jun 04, 2013 | Tablets & eReaders
ZEEPAD MID Android Tablet 7 Inch WiFi Logo
66 people viewed this question
Top ZEEPAD Tablets & eReaders Experts
Harrie
Sean Cole
Sean Cole
bobalix
Are you a ZEEPAD Tablet and eReader Expert? Answer questions, earn points and help others
