The amplifier turns on and automatically turns right off?
There will be 1 connection that has 12v or power. Connect your power lead from the battery to this terminal.
There will be 1 connector that has GND, GRND. Connect this wire to the body of your car in your boot, sand down area first clean of paint and dust to bare metal. Easy place is your seatbelt harness under your rear seats.
Then there will be 1 connector saying RMT which is your remote wire.
This wire connects behind your head unit and then to the RMT connector on the amp.
The remote wire turns power on to your amp on when ignition is turned on. The amp will turn off when ignition turned off. The same way your head unit turns on and off.
Hope this helps, If you cant find your RMT connection, Please state make and model of amp and I will locate it for you.
