Question about GE DCVH515EFWW Electric Dryer
DBVH512 blower wheel
Posted by ralph on
daniel hendrickson
    President:
  • GE Master
  • 1,922 Answers
G.E. part# WE16M15 blower wheel
Posted on Feb 23, 2013
BLOWER WHEEL BROKEN
In your instruction manual you should find a parts list, purchase a new blower wheel and install it. If it is an older unit it may be best to just replace it.
Feb 12, 2014 | Frigidaire Dehumidifiers
Error code E01
Models covered in this error code table :
DBVH512 DCVH515 DHDVH52
EEPROM is in the control board. Here is the part number WE4M385
Here are instructions to replace it. d9f57bce-8333-45b0-9402-b672a600df28.jpg
Jan 31, 2014 | GE DCVH515EFWW Electric Dryer
GE gas dryer mod. dbvh512 lights but goes of after a min or two trys to light but wont vent is clean.
If it works at all then stops heating that is a sign of them coils are are going out.
I have seen this problem many times. Replace those and all will be well.themobilian_472.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 17, 2010 | GE Dryers
How to replace a blower motor in a 1996 ford thunderbird lx
Removal
  1. Remove the glove compartment liner to gain access to the heater blower motor and blower motor wheel assembly mounting screws.
  1. Use a small screwdriver to remove clip retaining hydraulic damper strut.
  1. Remove four screws and remove the heater blower motor assembly and blower motor wheel assembly from the heater blower motor housing.
Installation
  1. Using a new seal, position the heater blower motor and blower motor wheel assembly to the heater blower motor housing with the flat side of the flange near the heater blower motor switch resistor (18591). Install the four retaining screws.
  1. Tape the heater blower motor power lead to the air inlet duct to keep the wire away from the blower outlet during installation.
  1. Install the heater blower motor and blower motor wheel assembly in the vehicle.
  1. Install the glove compartment liner.
Oct 07, 2010 | 1996 Ford Thunderbird LX
How do I replace the ac/heater blower moter?
Hope this helps....please don't forget to rate...thank you:
Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Disconnect battery negative cable from battery and properly isolate to prevent accidental reconnection.
  3. Disengage the wire harness connectors from the retainer.
  4. Disconnect the blower motor electrical connector.
  5. Remove the motor cooling hose.
  6. Remove the screws and remove the blower motor.
    NOTE
    Prior to removing a wheel that is to be reused, clean any corrosion from the blower motor shaft to prevent damage to the wheel mounting shaft.
  7. Remove the wheel from the blower motor as follows:
    • Remove the push clip.
    • Remove the wheel from the blower motor.
Blower motor cooling hose
Blower motor mounting plate
To install:
  1. Install or connect the following:
    • Wheel to the blower motor, if removed.
    • Blower motor and securely tighten the screws.
    • Motor cooling hose
    • Blower motor electrical connector
    • Wire harness retainers
Sep 15, 2010 | 2005 Mercury Grand Marquis
How to install a front blower motor in a 96 ford explorer
Blower Motor - REMOVAL & INSTALLATION
(see Figures 1 and 2)
Fig. 1: Exploded view of the blower motor mounting
Fig. 2: Exploded view of the blower motor and wheel (fan) assembly
Without Air Conditioning
  1. Disconnect the negative battery cable.
  2. Remove the air cleaner or air inlet duct, as necessary.
  3. If necessary, Remove the speed control module and the washer fluid reservoir.
Fig. 3: To remove the blower motor, first disconnect the electrical wire harness plug...
Fig. 4: ...then remove the blower motor cooling tube from the motor
  1. Disconnect the wire harness connector from the blower motor by pushing down on the connector tabs and pulling the connector off of the motor.
  2. Disconnect the blower motor cooling tube at the blower motor.
Fig. 5: Remove the blower motor attaching screws and the washer fluid reservoir...
Fig. 6: ...then slide the blower motor from the housing. Take care to not damage the blower wheel (arrow)
  1. Remove the 2 screws attaching the blower motor and wheel to the heater blower assembly.
  2. Holding the cooling tube aside, pull the blower motor and wheel from the heater blower assembly and remove it from the vehicle.
  3. Remove the blower wheel push-nut and/or clamp from the motor shaft and pull the blower wheel from the motor shaft.
To install:
  1. Install the blower wheel on the blower motor shaft.
  2. Install the hub clamp and/or push-nut.
  3. Holding the cooling tube aside, position the blower motor and wheel on the heater blower assembly and install the 2 attaching screws.
  4. Connect the blower motor cooling tube and the wire harness connector.
  5. Install the vacuum reservoir on the hoses with the 1 screws.
  6. If removed, install the speed control module and the washer fluid reservoir.
  7. Install the air cleaner or air inlet duct, as necessary.
  8. Connect the negative battery cable and check the system for proper operation.
With Air Conditioning
  2. In the engine compartment, disconnect the wire harness from the motor by pushing down on the tab while pulling the connection off at the motor.
  3. Remove the air cleaner or air inlet duct, as necessary.
  4. If necessary, remove the solenoid box cover retaining bolts and the solenoid box cover.
  5. Disconnect the blower motor cooling tube from the blower motor.
  6. Remove the blower motor mounting plate attaching screws and remove the motor and wheel assembly from the evaporator assembly blower motor housing.
  7. Remove the blower motor hub clamp from the motor shaft and pull the blower wheel from the shaft.
To install:
  1. Install the blower motor wheel on the blower motor shaft and install a new hub clamp.
  2. Install a new motor mounting seal on the blower housing before installing the blower motor.
  3. Position the blower motor and wheel assembly in the blower housing and install the attaching screws.
  4. Connect the blower motor cooling tube.
  5. Connect the electrical wire harness hard shell connector to the blower motor by pushing into place.
  6. If removed, position the solenoid box cover into place and install the 2 retaining screws.
  8. Connect the negative battery cable and check the blower motor in all speeds for proper operation.
Hope this help (remember comment and rated this).
Apr 23, 2010 | 1996 Ford Explorer
Furnace blower motor vibration
Check for a loose set screw on the motor shaft for the blower wheel.
Check the blower wheel for a missing balance weight.
Check the blower wheel for a dust buildup in the blades.
Check the blower wheel for a broken fin blade.
Check the blower motor shaft for excessive play.(more than 1/4 inch of play).
Check mounting screws on the blower housing.
Jan 04, 2010 | Ruud Heating & Cooling
The blower wheel is making a lot of noise. How do
Remove the front face of the dryer and continue to disassemble the dryer until you have access to the blower wheel. The blower wheel is manufactured with a D shaped hole in the middle. If the whole on the inside of the blower wheel become rounded, then the wheel rotates at a different speed than your motor, causing the loud vibrations you have been hearing.
Using the pliers, remove the holding pin & blower wheel clamp. The clamp is the green ring and the pin is the small horse-shoe shaped pin with an arrow pointing to it.
Pull the old blower wheel off. You should see that the whole in the center is round rather than D-shaped.
Put the new blower wheel in place.
Replace the ring clamp & holding pin.
Re-assemble the dryer.
Sep 01, 2009 | Amana Dryers
Ge Model DBVH512 is blowing cold air
Check the thermal fuse, that is usually what it is. Cheap and simple fix.
Aug 13, 2009 | GE Dryers
GE DCVH515EFWW Electric Dryer Logo
63 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Marc Taylor
Are you a GE Dryer Expert? Answer questions, earn points and help others
