Question about Samsung DVD-V9800 DVD Player/VCR
HDMI and/oor Componant connections
I am confused. Do you hook up both HDMI and Component wires to the TV,or just one or the other?
Posted by cph208 on
Dennis Engelking
    President:
  • 643 Answers
Just one or the other HDMI will give you the best picture
Posted on Feb 04, 2013
Optoma hd65- componant signal OK but no hdmi signal found
whats the reason for no display on hdmi to hdmi connection- to the x box display is fine-?
Jun 25, 2012 | Optoma HD65 DLP Projector
Where do the blue, red, and green wires that plug into the DVD player plug in? Are they supposed to plug into the TV set?
it is known as componant input & out put.if your tv has component input then connect three rca wires from dvd to tv and change input mode to component.if your tv doesnt have compo in then u can connect it to v in yello wire ( only one wire)
Jun 04, 2010 | Samsung DVD-V4600 DVD Player/VCR
I received a cobydvd224 as a gift but don't know how to connect to my cable box-pls help
There may be several ways, depends on your TV. Your TV may have: HDMI, Component, Standard Video, or RF in. You need to match one of those connections to the DVD players available connects. For example... if you have a newer HD TV your cable may be connected to the component input of the TV if there's an HDMI input on the TV and an HDMI output on the DVD Player, simply connect them together and put the TV in HDMI mode.
I know it's confusing sometimes, but read the book and you should be able to figure it out. Let me know if I can help more...
Geno
Dec 06, 2009 | Coby DVD-224 DVD Player
I have a onkyo 706 reciever and I can't get any TV sound
Component (i.e. TV) should be connected to plug labeled IN (signal IN receiver).
Jul 15, 2009 | Onkyo TX-SR606 Receiver
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
Component to HDMI
why dont u connect the xbox directly to the tv via HDMI cable? the output will be fantastic.The component cables just cannot give a better resolution than HDMI.
As for connections,i am not in favour of component and HDMI together.
May 18, 2008 | Pioneer VSX-92TXH Receiver
HD Picture is Scrambled, but Has Sound
I had the same problem
you have to set up the componant on DTV.
the signal my be hd 1080i and the only connection with componant that can support this is the DTV port.
the other componant connections only support 480,
good luck
Apr 06, 2008 | Mitsubishi WS-55711 55" Rear Projection...
HDMI audio problems with my sharp LC42D64U
the problem is that your cable box is putting out too low of a bandwidth to your tv and is cutting out completely. Since its all digital either its there or not. try switching to componant cables. Cable boxes only support up to 720p anyway so you wont sacrafice any quality.
Hope this helps
Mar 02, 2008 | Televison & Video
Problem with component input and 720p HDMI output
does your cable box have an hdmi output? if it does try an hdmi cable instead of componant cables[ i know the hdmi cables aren't cheap] if not, if the reciever has componant outputs, use them instead.
hope this helps
wg
Feb 02, 2008 | Onkyo TX-SR605 Receiver
Samsung DVD-V9800 DVD Player/VCR Logo
65 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
