Question about Samson C01U Consumer Microphone
SOURCE: tips on Using the Samson C01U with Cakewalk Pro Audio 9
Try this:
Control Panel > Sound Audio Device > go to Voice Tab > check your drop down list for Voice Recording and make sure you put on Samson C01U then test your hardware and see you get any pick up. I had to research on what to do.
Now my problem is why the mic is only picking up on the left side of the ear instead of the right. =/
Posted on Jan 08, 2009
SOURCE: static with playback on samson-gtrack with windows xp
i have the same problem with my g-track on a macbook im just going to take the thing back
it works for a feww min when i first start recording the is falls apart
Posted on Aug 16, 2009
SOURCE: Playback only on left speaker
The quick, easy solution is to change your microphone to mono recording. In the attached YouTube clip, I'll show you how to do that.
The short and simple is to go to your Mac HD -> Applications -> Utilities -> Audio MIDI Setup. Select your C01U USB device, and set it to 1ch 16bit. This will set the microphone to record in mono, equally over both speakers.
Posted on Mar 09, 2010
SOURCE: i have a samson c01u
Installing SoftPre usually fixes the problem. http://www.samsontech.com/main/misc.cfm?pageID=45 Good Luck, Cody J.
Posted on Dec 20, 2010
SOURCE: I only hear my mic mainly on the left channel. How
i found the problem i also fixed the ******* problem in windows 7 theway to fix is that go to recording devices in the volume mixer (i mean in the taskbar the speaker icon right click it recording devices and it will show your mic if ya hav been pluged it) the after going to recording devices then double click the mic u are using then an windows will appear . go to enahcement tab untick "dc offset cancellation". thats it
Posted on Feb 12, 2011
Apr 05, 2014 | Samson C01U Consumer Microphone
Aug 27, 2011 | Samson Audio C01upak C01u Microphone and...
Apr 27, 2011 | Samson C01U Consumer Microphone
Jan 21, 2011 | Samson C01U Consumer Microphone
Sep 28, 2009 | Samson C01U - USB Studio Condenser...
Aug 15, 2009 | Samson Audio C01upak C01u Microphone and...
May 23, 2009 | Samson C01U Consumer Microphone
Mar 29, 2009 | Samson C01U Consumer Microphone
Feb 25, 2009 | Samson Audio C01upak C01u Microphone and...
Nov 26, 2007 | Samson C01U Consumer Microphone
Jun 01, 2014 | Samson C01U Consumer Microphone
Mar 15, 2013 | Samson C01U Consumer Microphone
Apr 21, 2012 | Samson C01U Consumer Microphone
41 people viewed this question
