Text jumps around
Click the Windows "Start" button or press the "Windows" key. The "Start" menu opens. Type "Cursor blink" in the "Search programs and file" text box. A list opens. Click "Change Cursor Blink Rate." The "Keyboard Properties" window opens. Click the "Speed" tab. A list of options appears. The "Cursor Blink Rate" section shows a "Cursor Blink Rate" slider displaying a range from "None" to "Fast." Click and drag the slider button to the "None" area in the far left portion of the "Cursor Blink Rate" scale. Click "Apply." Click "OK." The cursor stops flickering on the screen.
SOURCE: cursor jumps around the screen randomly when I type
well..that can happen when the palm of your hand touches the touchpad, as you are typing..happens to me all the time. try it with your hands a bit more over the top fo the laptop..
SOURCE: Dell Cursor Typing Blinking Problem
this is because you must deactivate your touchpad. you can do this by holding the Fn key and pressing the F* key that shows a picture of a touchpad in the same color as the Fn.
or you can go to control panel and turn it off in the mouse settings. but just attaching a mouse will allow the touchpad to stay active and therefore still be sensitive enough for your hand to "tap" th cursor.;
Good luck and pls rank this response! :D
SOURCE: cursor skipping and jumping back into previously typed text
Have a D600 myself and found anothe post that worked for me!
First, my problem was replying to emails the cursor would jump when typing usually back up into the middle of the text somewhere.
If this is similar, read on.
First, go to Dell's website, downlaod the latest driver for the Alps Touchpad: http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R113813&SystemID=LAT_PNT_PM_D600&servicetag=&os=WW1&osl=en&deviceid=2514&devlib=0&typecnt=0&vercnt=7&catid=-1&impid=-1&formatcnt=1&libid=17&fileid=149404
Download the driver but do not install yet. Note, this is for a Dell Latitude D600, Windows XP. Vista may have a different driver.
Open Control Panel/Mouse/TouchPad Tab/Touch Sensitivity Button. Open Touch Sensitivity, adjust below the halfway point on the slider. Try different settings, you may also want to check the "Tap off when typing" box.
If you do not show these properties as above, you probably don't have the latest driver installed. In that case, install the driver you downloaded above then come back and refer to the instructions.
I spend 90% of my day on this D600 and really love it, not a speed demon, but light enought to carry with one hand and is a great email/browser machine as you probably already know!
Before installing tis driver
SOURCE: how to remove battery on dell inspiron 1150
From Dell manual MAIN BATTERY
"Slide and hold the battery-bay latch release on the bottom of the computer, and then
remove the battery from the bay.
Image -
http://support.dell.com/support/edocs/systems/ins1150/sm/begin21.jpg
CMOS battery is located on the systemboard and requires disassembling the computer
