Question about GE Profile Harmony DPGT750EC Electric Dryer
Display locked into the troubleshoot display.
Display goes to troubleshooting on plugging it into the 220VAC and the membrane switches become useless. Is it the main logic board?
Posted by pjmonat on
daniel hendrickson
    President:
  • GE Master
  • 1,922 Answers
More likely its the I.U.(interface user) board that controls the logic board
Posted on Feb 23, 2013
Samsung microwave error messages
This is a sign the keypad has a shorted membrane.
Mar 16, 2012 | Samsung Microwave Ovens
Good Morning, I bought a used Magic Chef stove. I don't have the manual. The alarm/bell keeps going off. The display shows "F-1" Would you please let me know how to turn off this alarm? I keep...
F1 Defective Touch Pad or Membrane
Replace Touch Pad or Membrane
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 20, 2010 | Magic Chef Kitchen Ranges
Display showing F2E1
HI. This code will appear if the key pad becomes unstable. This may be a loose cable, or faulty control board. Use the procedure to isolate the issue.
1. Check The keypad connector, which will be located on the backside of the control board, for a firm connection. Pull off the connector, and re-attach. If the code comes back, after the re-attaching method, move on to the next step.
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models may incorporate the keypad and control board as one unit. In this case, replace the control board (also referred to as the ERC or clock).
Dec 25, 2009 | KitchenAid Kitchen Ranges
How to start oven in PROPANE STOVE
Print the following infore for future ref if you wish. How it works is simple tage a look at it in Motion
Component Test Procedure Results
Electronic
range control
F1−1 –Upper Oven >650°F with door unlocked.............................
F1−2 –Lower Oven >650°F with door unlocked.............................
F1−3 –Upper Oven >950°F with door locked.................................
F1−4 –Lower Oven >950°F with door locked.................................
F1−7 –Membrane switch is not responding ...................................
F3−1 –Upper sensor is shorted at (< 100 ω) or
open at (>5 K ω) ...............................................................
F3−2 –Lower sensor is shorted at (< 100 ω) or
Check actual upper oven temperature,
if > 650°F check sensor.
Check actual lower oven temperature,
if > 950°F check sensor.
Check membrane switch for connection or damage.
Check upper sensor, harness, and connections
Engineering
Test Mode
Press BAKE pad.
Enter 100°F using the number pads.
Immediately push and hold BAKE pad for appropriate oven
approximately 3 seconds.
This mode can also be entered by pressing the hidden pad
for 3 second located to the left of the lower oven light pad.
Used to view the actual oven temperature for both ovens at all
times, even when an oven function is active.
This mode will also display the current fault code for 5
seconds in the time digits.
Fault codes
accessed
through
Engineering
Test Mode
F0−0 –No fault .................................................................
F1−5 –Upper hardware failure within control ....................
F1−6 –Lower hardware failure within control.....................
F1−8 –Shorted key in membrane switch ..........................
F1−9 –Internal communication errors within control .........
F1−A –Upper latch switches ............................................
F1−B –Lower latch switches.............................................
F1−C –Upper door switch.................................................
F1−D –Lower door switch.................................................
F1−E –Sensor input not calibrated ...................................
F1−H –EEPROM error .....................................................
F1−L –Temp in ovens are the same for long period .........
F1−N –Internal voltage on control not working .................
F9−1 –Upper lock switch is not correct.............................
F9−2 –Upper unlock switch is not correct.........................
F9−3 –Control does not see upper door lock....................
F9−4 –Lower lock switch is not correct.............................
F9−5 –Lower unlock switch is not correct.........................
F9−6 – Control does not see lower door lock ...................
EE –Control cannot read E-PROM. Unit will shut down.
Default from factory
Replace control
Replace control
Check membrane connection
Replace control
Check latch wire harness
Check lock wire harness
Verify sensor is operating properly
Replace control
Replace control
Check lock wire harness, and lock switch
Disconnect power for 60 seconds. If EE reappears, replace ERC
Test Mode This mode must be activated within the first 5 minutes of
power up.
Press BROIL and CANCEL pad for approximately 3 seconds.
If oven temperature is greater than 400°F, the Test Mode
cannot be activated or will abort if active.
Press and hold individual pads for 4 seconds to activate.
Display will have dashes in all segments to indicate the mode is
active.
Upper Bake: Energizes upper bake element
Lower Bake: Energizes lower bake element
Upper Broil: Energizes upper broil element
Convection Bake: Energizes convection fan
Upper Oven Light: Energizes upper oven light
Lower Oven Light: Energizes lower oven light
Upper Clean: Energizes upper motorized door lock
Lower Clean: Energizes lower motorized door lock
Stop Time: Energizes Beeper
Cook Time: Displays error codes
Timer 1: Energizes ROM version
Timer 2: Energizes EEPROM version
Keep Warm: Cooling Fan
Clock: All display segments light
If functions do not perform as specified, replace ERC
Oven
temperature
adjustment
Push BAKE pad.
Enter 550°F using the number pads.
To decrease or increase oven temperature. Push AUTO SET
pad until negative or positive numbers appear. Oven can be
adjusted from -35° to +35° (-37.2° to + 1.6° C) in 5° F (2.7° C).
To avoid over adjusting oven move temperature -5° each time.
Push OVEN CANCEL button.
Sep 04, 2009 | Frigidaire 30 in. Electric Gallery Series...
Advantium 120 (Display Pad is not Illuminated or Working)
try removing the touch pad/switch membrane and cleaning connections on ribbon cables. if problem still exists replace switch membrane.
Phil
Jun 11, 2009 | GE Advantium 120 Convection/Microwave Oven
Inspiron 8500 99% dead
your laotop problem most from display unit (ATI MOBILITY RADEON 9000), you need consider
1) first you need to make sure the EXT VGA diaplsy is ok or not, if both display are same problem, please do next
2) if the display card is separat to motherboard you need check the card connection with the motherboard, there is pair plug/socket
clean it and set back. still bad, need to change one
3) if the display card is on board chips you cant change it, you have to find a special technician to do BGA repair
4) if EXT VGA display normal you need check LCD cable connection and LCD panel, this step please keep in touch me
hope help you to deal well
May 14, 2009 | Dell Inspiron 8500 Notebook
Beeping in my Neptune Dryer
This is a mystery to me. Try typing into google "beeping sound on Neptune dryer". There may be a solution on there from Neptune or someone who has had a similar problem.
Jun 14, 2008 | Maytag Neptune MDG5500AW Gas Dryer
DISPLAY ERROR F1-8
F1-8 commonly means shorted membrane. Unplug or shut off the circuit breakers for 15 minutes, plug back in/turn back on, if problem persists replace membrane, if they are integrated parts replace control board (some come with membrane on parts vary)
Always shut off power before any repair attempts electrically
May 01, 2008 | Jenn-Air JGS8850ADS Gas Kitchen Range
Operational failure
Your keypad or control board may have moisture or grease on them, but your keypad (membrane switch) is likely going bad. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find a keypad (if available) by entering your exact model here: http://www.samsungparts.com/search/search.asp
Sep 15, 2007 | Samsung MW8553G Microwave Oven
GE Profile Harmony DPGT750EC Electric Dryer Logo
349 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Marc Taylor
Are you a GE Dryer Expert? Answer questions, earn points and help others
