Jensen's VM9312 Car DVD Player Logo
Question about Jensen's VM9312 Car DVD Player
What are the green and white wires for on my Jensen VM9214?
Posted by Luis Rodriguez on
Richard Foster
    New Friend:
  • 88 Answers
The green and white wire is the parking brake wire.
Posted on Oct 15, 2013
2 Related Answers
djsyco
Richard Foster
  • 88 Answers
SOURCE: What does the green/white wire connect to on my
It connects to the Back-up camera if you have one installed. if not leave it out of the hook up.
Posted on Jun 26, 2009
ZJLimited
ZJ Limited
  • 17970 Answers
SOURCE: my jensen vm9214 wont play
This is one video lock condition that you need to bypassed. In THIS LINK can find the solution: Jensen-Video-Bypass-Lockout-VM9214-VM9414-VM9324
I heard this same problem, if it plays when its parked then it has a little safety feature that involves a wire, maybe pink in color for your headunit that will only allow it to play when parked. Now if you splice it into the red or yellow, I'd choose red since its not constant, it will play movies anytime.
If it won't play them even when parked then it is not hooked up to a wire or its hooked up to ground and therefor should be hooked to a positive wire, red or yellow. If you didn't put it in yourself then you can take it to an audio shop, maybe check in phonebook for someone local.
But the easy way would be to use a bypass code since there is ojne for your hu. I copy these instructions from ecoustics.com The parking brake bypass procedure is as follows:
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
6: Use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another.
I don't know if it really works but you could try it, if not use the wiring method above: ecoustics.com/bbs/4/278797.
Hope helps.
Posted on Oct 14, 2010
I have a Jensen vm9214 touch screen
Good. It is a grand set. Keep it. Never allow anybody even to touch on it.
1helpful
Why is my My Jensen VM9214 stuck on camera mode
Check your wires, theres a wire for the reverse if your going to use a back up camera, if not do not connect it, you may have had it connected through a speaker wire, if so then thats your issue and once you wire it up right it wont do that any more, had the same issue and thats what fixed it hope this helps
Jensen vm9214 when i hook my indash to battery only the src button is red it wont turn on t
Did you connect the power, ground and accessory? When doing a bench test for operation, these wires need to be connected.
I would like to replace the flatwire ribbon that connects the screen to the unit. It is cut. Do you have the part number or location wher I can purchase this part?
go to jensen online they should have the part you are looking for take the old one out and go buy the pics on the site count the wires and plug pins and try to match the colors cause sometimes they will change good luck
2helpful
Red light comes on but the unit wount turn on
The red light is associated with the memory (constant 12 volt power). You also need switched 12 volt power (power with key turned to accessory)for the unit to turn on. If you installed the system yourself, you are looking for 12 volts on the red wire of the Jensen unit. If power exists at the unit, check the fuse of the unit and the fuse of the vehcile.
How do I get GPS & bluetooth stufff to go with this system ?
You need the Jenson BTM15 (bluetooth module) and the Jensen NAV105 (gps) in order to have navigation and bluetooth connectivity thru this head unit.
http://www.mobile.jensen.com/accessories/?sku=NAV102
http://mobile.jensen.com/bluetoothcarkits/?sku=BTM15
These units sell for around $50 (btm15) and $200 (nav102) on amazon.com
Willplay fine but when i raise the volume passed thirty it shuts off compleatly and then it comes back on.
Check the power and ground wires going to the head unit. I have seen this problem before, and in those cases it was due to the battery not supplying enough power and the power wire being too small. Try using 6-8 gauge wire for the power and ground.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Top Jensen's Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Jensen's Car Audio and Video Expert? Answer questions, earn points and help others
