Question about Lazy Boy La-Z-Boy Power Lift Recliner Cashmere
My remote control for power chair will turn on the heat but not operate the up and down switch
Posted by earlenelena on
Tom Chichester
    Top Expert:
  • Lazy Boy Master
  • 56,023 Answers
The control unit may be defective, but also the cable may have been damaged
Posted on Feb 04, 2013
How do you wake up a controller that is asleep?
The majority of controllers have a sleep timer. If the chair is on for a specific time period without use, it turns itself off, or, goes into a sleep mode. The chair is in a sleep mode when the operator tries the move forward and the chair does not move and lights on the controller blink rapidly.
To solve this, simply turn off chair, wait 10-30 seconds and turn chair back on. You should be able to operate as normal.
May 31, 2014 | Pride Mobility Pride TSS300 Power Chair -...
Need wiring diagram of chair, schematic of remote and p.s./controller board
i have ALINCO MCR2100 massage chair it operate 15 min and then it cut off and operate after 1 hour when operate it no work
Jun 20, 2011 | Human Touch Ijoy 100 Robotic Massage Chair...
My lift chair is stuck straight up and my remote does not light what can be the problen as i have power to the chair
God people like you are my reason for being here,im disabled myself.Please visit:-www.alldatasheet.com .In your case i would crawl out to you to help,but am mostly in bed trying to build strength for 2 operations i can only risk having awake lol.thats true.so if you have a prob with anything,[ask again or better still seek someone to help you search that site & the good news ITS FREE,Colin.
Mar 11, 2011 | Pride Mobility Products Casual CL30KD Lift...
Miss operation to launch "Control
When the control panel lock ON of the projector so that the projector can be operated only with the REMOTE CONTROL.
If you loos your remote control then keeping the POWER key on the projector control panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you press and hold the MENU key for about10 second when the power is on the lock will be released and "panel key lock" is automatically set to "OFF"
Feb 23, 2011 | Sony VPL-CX70 Multimedia Projector
The power funtion drive on my Invacare Storm TDX 5 wheelchair, which operates the tilt, recline, elevating leg rest and seat elevator has stopped working. The drive switch as it appears on the LED screen...
1) Yes your power seat functions can be programed into your drive 4,You'll need a programmer or have to take it into a shop.
2) yes the chair can be manually elevated down,You'll want to take it to a shop for that ,because it requires jumping the power to the seat elevator and swapping the wires around and I would never recommend my customers to do such a thing because of electric shock or burning up the chair.
If your chair has a four wat toggle switch("what controls your power seat functions elev,recl,telt,ext) If thats what your using right now there may be a red light that comes on in drive lock out ,If that light is not on follow that wire all the way down it may have been pinched or cut.If so it will need to be replaced.
Problems like this one is hard to trouble shoot over text or phone ,if your four way switch cord is cut or smashed .Your gunna have to take it into a shop just to make sure ,It didnt cause any electrical problems in your chair .
Good luck hope i had the chair in front of me so i could help you more.
Jan 15, 2011 | Invacare Health & Beauty
Re: Pride Jazzy 1103 Ultra. Chair is acting like the seat is still elevated and the speed is set to slow (with indicator light flashing). Please let me know what should I be checking?
When the power seat lift lowers down, there is usually a bracket that pushes a button under the seat that tells the motor the seat is lowered and the power chair is safe to operate. Sometimes the bracket can get bent and the button does not get pressed when the seat goes down. Check under the seat around the seat post for the button and make sure the bracket is connecting to it. Carefully bend it back into place if it is not hitting the button properly. If the bracket came off, it will need to be replaced.
Aug 25, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Can the speed of the Jazzy Power chair be increased beyond the setting on the armrest remote controller?
Make sure that your tires are properly inflated and that you are not carrying more weight than the power chair will allow and that your batteries are fully charged.
If you got your chair second hand, sometimes the previous owner has the technician change the controller settings to "dampen" it to slow it down to allow them greater response time and control. The technician can reprogram the controller to take it back to 100%. If you got the power chair new, it should be at 100% already.
Take it easy, HotRod. It's a medical device, not a car!
Jul 20, 2010 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Chair will not go up or down
The clicking is the mechanical part of the switch, but the electrical part may still be bad. In all the chairs I have serviced, it has always been the switch. The switch itself goes for about $25 plus labor to change it, and the whole control unit retails for about $100. the best test is to take the controller apart and short out the center wire to either side and check the chair for movement.
Jan 22, 2009 | Pride Mobility Products Casual CL30KD Lift...
Not getting any power to chair
Make sure there is power at the outlet. Check the fuse panel. If there is still no power then check to make sure there is no GFI (ground fault interupt) switch on the chair itself. The GFI is a 2 button switch that will say "Reset" and "Test"
Nov 30, 2008 | Interactive Health Black Leather Ht 130...
Lazy Boy La-Z-Boy Power Lift Recliner Cashmere Logo
637 people viewed this question
Top Lazy Boy Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Lazy Boy Furniture Expert? Answer questions, earn points and help others
