How would i know if the lcd of my AOC 917Sw 19 inch LCD Monitor was replaced with another LCD monitor which is defective?
SOURCE: AOC LM729 17" LCD Monitor - Manuel
I assume you only found the 4 mount screws in the back... You also need to take off the front silver edging - it pops off with some negotiating, but if you find the right spots and don't pry hard it will come off clean without too much difficulty. Then take out the screws that hold the screen inside and it should drop out.
SOURCE: monitor
hi auntie
while the monitor is OFF press and hold the MENU key,switch ON the monitor while still holding the MENU key and voila it is unlocked
Hope this fixes you
SOURCE: AOC 917sw 19 inch monitor resolution issue (same as above)
Have you try the following resolution values:
1280 x 768
Usually its the standard for widescreen view
Please don't forget to rate if answer is useful
SOURCE: 19" aoc lcd monitor flashes pink constantly and turns black
THIS COMPUTER THAT I AM ON ALSO DOES THE SAME THING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! GRR...................=.="""""
SOURCE: I am getting a INPUT NOT SUPPORT message for my
The resolution selected in normal mode is not supported by your monitor.
Instead of booting into safe mode, boot into VGA mode - this should allow you to change the resolution - change it to one that works and then you should be able to use normal mode.
Hope this helps,
Sherwin
