How do I turn the ringer on. Through the prog menu the ringer is turned on all the way to hi. The phone will not ring when using magic jack.
Ring volume
The handset ringer volume can be adjusted from five levels.
• Press MENU/SELECT to display menu when in idle mode.
• Press up arrow or down arrow to reach Setup HS. Press MENU/SELECT.
• Press up arrow or down arrow to reach Ring volume . Press MENU/SELECT.
• Press up arrow or down arrow to scroll through the choices and a sample of each ring
volume will be played. Press MENU/SELECT to confirm.
• The screen displays Stored and you'll hear a confirmation beep.
You can adjust the ringer volume by pressing VO L+/VOL- on the
telephone base when the telephone is ringing.
