Question about Health & Beauty
Do electric toothbrushes require a different amount of toothpaste compared than manual toothbrushes?
Posted by roberta caffrey on
Edward Randall
    Habit-Forming:
    New Friend:
  • 123 Answers
No, you need to take same amount of toothbrush just like your regular tooth brush to clean your teeth properly. Toothpaste is essential for delivering fluoride and maintain oral health.
I would recommend to check these reviews to get more information about electronic toothbrush and best comparison:
Top 5 Best Electric ToothBrush Reviews
Posted on Aug 06, 2015
Anabelle Lee
    New Friend:
  • 68 Answers
No, you should put the same amount of toothpaste on all types of toothbrushes. You should put enough so you can clean your teeth well.
Posted on Feb 04, 2013
2answers
tip
Five steps for brush your teeth perfectly
Aim the toothbrush at a forty five degree attitude towards the gum line.
Use a pea-sized quantity of toothpaste.
Use a gentle round motion.
Repeat on the interior surfaces.
Use a mild backward and forward motion at the chewing surfaces.
Spit out the toothpaste after brushing.
You do not need to rinse, as the small quantity of fluoridated toothpaste left to your mouth after spitting maintains to defend in opposition to enamel decay.
on Feb 12, 2020 • Medical
tip
How To Fix Scratches With Toothpaste
One of the worst thing about buying a used video game is worrying about scratches? In fact sometimes the scratches are so bad that your system will no longer recognize the game. I've been in this similar situation and though I wasted my money. However then I tried the Toothpaste Trick and I have been recommending it ever since.
The first thing you want to do is get some white toothpaste. You can try the other types or brands but I recommend regular white toothpaste. From there apply toothpaste to where the scratches are on your disc. Use a toothbrush or cloth and apply the toothpaste to the scratches. Make sure to be careful and avoid getting toothpaste near the center of the disc.
Once the toothpaste is on those scratches wait about 5-10 minutes. Once time is up go back to your disc and begin removing the toothpaste. You can try using another cloth however the toothpaste might be sticky. Get another cloth and apply a very tiny amount of water onto it. Use the wet cloth again to remove the toothpaste and then use a dry cloth to make sure the disc is try. Wait another 5 minutes to complete the process.
After that, your all finished! Your disc should be working good as new again and it only took a few minutes. Finally as stated earlier, be careful doing this. Make sure that you've tried other options such as simply cleaning the disc with a cloth before trying this trick. It should be used as a last resort.
2answers
What are the advantages of manual toothbrushes over electric toothbrushes?
The main advantage of manual toothbrushes is the cost. They are much cheaper than electric toothbrushes. Whereas an electric toothbrush can cost you $50-$100, manual toothbrushes can be bought for just a few bucks. Another advantage is that manual toothbrushes come in different sizes and colors, so there's a larger variety to choose from.
3answers
What are the advantages of electric toothbrushes?
Electric toothbrushes are an excellent tool to keep your teeth clean and healthy. They offer many advantages:
They allow you to remove plaque more efficiently and quicker than manual toothbrushes.
You don't need to brush hard in order to get good results. This means that you are much less likely to injure your gums.
People who suffer from physical conditions like arthritis find electric toothbrushes as a great replacement to manual toothbrushes because they are easier to grip and you don't need to use as much physical power to get your teeth cleaned (the powered brushes do the cleaning).
It is more fun to brush with electric toothbrushes compared to manual toothbrushes, especially for children.
What accessories do I need in order to brush my teeth?
You need an extra soft bristled manual toothbrush, toothpaste you like which must contain fluoride and a mouth rinse.
2answers
What are the different types of toothbrushes?
There are three types of toothbrushes that are commonly used:
  1. 1. Manual toothbrush
  2. 2. Rechargeable electric toothbrush
  3. 3. Battery power toothbrush
For more detailed information on these toothbrushes, check out Oral-B website
I want to know how to clean my nixon watch it is rubber and neon green... help its relly dirty haha
check this out, cleaning watches,jewelery, or even diamonds, this realy works-take a soft toothbrush,and aply a small amount of toothpaste to whatever your cleaning, let set for a few moments, until not slimy, then with a small amount of water-brush heavily,and often all over -repeat as often as needed until satisfied. this may take several attempts,but it will bring a new luster to just about anything. dry by using clean soft cloth. enjoy
May 28, 2011 • Watches
Health & Beauty Logo
Top Health & Beauty Experts
Rob Hill
Rob Hill
ray gallant
ADMIN Canada
ADMIN Canada
Are you a Health and Beauty Expert? Answer questions, earn points and help others
