My handle bar is not locking into place and moving up and down when i try to use. Can i fix this problem and if so how much? Thank you
SOURCE: Handle bar issue...
CONTACT BUGABOO
PHONE: 1-800-460-2922
E MAIL: [email protected]
WEB SITE: WWW.BUGABOO.COM
SOURCE: Bugaboo Frog Handle Bars Not Locking into place
We had a similar problem with our Bugaboo Cameleon. The right-hand hinge of the frame would not lock and the button was permanently down. What had happened was the handle extension switch housing had come unscrewed and slipped up the frame, causing a small spring to fall out. The lock switches each have a spring which pushes down on a rod inside the frame to lock the hinge. To access the spring, unscrew the handle extension housing and slide it up the aluminum frame. I replaced the missing spring and the frame works perfectly. If the problem is with the spring, this should work. Alternatively the problem may lie inside the lock switch housing, which contains a very simple mechanism which slides the lock rod up and down. This can be unscrewed as well. As far as I can tell, the actual hinge assembly itself is a sealed unit and can't be opened, but hopefully, you won't have to.
Good luck,
Ben
SOURCE: Main Chassis bar won't lock on one side
We had a similar problem, the right-hand hinge of the frame would not lock and the button was permanently down. What had happened was the handle extension switch housing had come unscrewed and slipped up the frame, causing a small spring to fall out. The lock switches each have a spring which pushes down on a rod inside the frame to lock the hinge. To access the spring, unscrew the handle extension housing and slide it up the aluminum frame. I replaced the missing spring and the frame works perfectly. If the problem is with the spring, this should work. Alternatively the problem may lie inside the lock switch housing, which contains a very simple mechanism which slides the lock rod up and down. This can be unscrewed as well. As far as I can tell, the actual hinge assembly itself is a sealed unit and can't be opened, but hopefully, you won't have to.
Good luck,
Ben
SOURCE: Loola handle won't lock into position
I had this problem and was discussing it with another loola mum. If you pull the handle and push down on the top of the bit it locks into at the same time, it locks first time - I've had months of frustration due to this and it was solved so easily!
SOURCE: i need a new chassis as the handle bar wont go down
You can purchase a new handle from the suppliers or the retailier where you purchased the pram as this is much cheaper.
Hope this helps.
