Question about Motorola Mag One BPR40 Two Way Radio
Bpr40 transmit but receive - Motorola Mag One BPR40 Two Way Radio
Motorola bpr40 no modulation
check your final for correct voltage . Also your driver then your Integrated circuits' . If they are bad then replace them .
Nov 15, 2016 | Motorola Radio Communications
BPR40 Receiving a static reception when someone is talking
Several things need to be checked. Fully charged battery. Antenna, make certain it s tight and unbroken. Wiggle the antenna while receiving, if reception improves, it is the antenna or the antenna jack. Then wiggle the on/off vol switch, same thing, if reception improves, it is broken or needs to be resoldered. Then I check the speaker. Speakers gather metal particles, as they get more and more, the speaker distorts and it sounds like static. Use a powerful magnet, run it over the speaker grill and see if anything comes out. I put plastic wrap on the magnet for easy cleaning. It could still be a bad speaker. Last, I check programming. All of this is done at our shop regularly and I suspect most radio shops follow the same procedures, maybe in a different order. Post if this helps or not.
May 17, 2016 | Motorola MagOne BPR40 UHF 8-channel...
Will not transmit or receive
Contact Motorola Solutions. Get Support .
Mark
Motorola Mobility Support
Jul 17, 2015 | Motorola Mag One BPR40 Two Way Radio
Motorola BPR 40 will transmit,but not receive through the microphone. Works fine as a handheld
You may have one of three problems: Your audio accessory jack is bad, you are using the wrong mic for the radio, or your mic is bad. Try the mic on a known good BPR40 and if it test good, if so, your BPR40 with the problem needs a new audio accessory jack. (Repair is available for this model.) We have found the BPR40 will only work properly with the remote speaker mic designed for it, despite some other Motorola mics appearing to fit the jack. Construction grade mic PMMN4013 is a good option, as is the lightweight PMMN4077.
Jul 08, 2015 | Motorola Radio Communications
Mt mag one bpr40 uhf 450/470 will receive but will not transmit. green light is on all the time
It probably has "busy channel inhibit" turned on in the menus, and the squelch is open, thus making it think there is a signal on the channel you're trying to use.
Sep 01, 2013 | Motorola Mag One Bpr40 Uhf 4w 8 Channel...
My mag one bpr40 will not transmit. the green light is on all the time. it will receive. how do i fix this problem
Green light coming on and staying on... Sadly nothing the end-user can do to alleviate this problem themselves. It is usually repairable by a trained/equipped repair facility.
Sep 01, 2013 | Motorola Mag One BPR40 Two Way Radio
My BPR40 transmits to one radio but can't respond ?
Check your PL/DPL settings among the radios. You may not have them programmed the same as one another. PL (aka private line) blocks out other users who do not have the same code as one another. Your radio which receives could be set with no PL code and it receives and hears every thing, so it would hear the other two, but not talk to them if they have a PL code setting.
Another way to check this is typically the dealer who programmed them will have the side button directly under the PTT programmed for Monitor. If you press this button a short press you should temporarily go into "open squelch" and you would be able to hear everything on your frequency. Try pressing this button on one of your "two" radios and see if they can hear the "one" radio. If so, you know it is a programming issue. (provided the button is programmed to Monitor). If pressing the Monitor button does not allow temporary communication, you have another issue.
If the green light on the radio seems to come on and stay on continuously, the radio is in need of repair. (Average flat rate repair on tehese BPR40s are around $79 currently at many repair centers.)
Best regards.
Jan 14, 2013 | Motorola Mag One BPR40 Two Way Radio
We use these radios in a race car.They work fine until you hook up the headset for the spotter to use and it drains down the battery real fast.Brand new batteries.
It is possible the headset you are using is not the one engineered for the radio, and draining the battery. Or this radio is being transmitted on heavily and running down the battery. You might try changing headsets and see if the problem clears up. Not all headsets compatible with other Motorola Radios will work with the BPR40.
Best regards.
Aug 01, 2011 | Motorola Mag One BPR40 Two Way Radio
My magone BPR40 radio isn't sending when PTT is pushed. It is receiving fine. Any suggestions?
A couple of thoughts:
1) Check the mic hole and see if it is covered or clogged with debris.
2) Does your PTT button seem hard or the opposite, mushy? You could have an internal PTT issue. The PTT is a common failure part on 2-way radios. Feel around for the 'sweet' spot and see if you can make a simple or partial transmission, or if it will even momentarily open up the receiver on the other unit. If so, your radio is in need of repair. It would likely need a new internal PTT. (At most repair centers where the BPR40 is repaired the flat rate repair currently are around $69 for the BPR40)
3) Has any reprogramming been recently done on the radio? If so, double check the programming to be sure your PL/DPL code is set the same as your other radio.\
4) Check your battery. Trade batteries with the other unit and see if the problem changes. It takes more energy to transmit than to receive.
Best regards.
Jun 15, 2011 | Motorola Mag One BPR40 Two Way Radio
Motorola Mag One BPR40 Two Way Radio Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
