Question about Miele 24 in. G638 Plus Free-standing Dishwasher
Brand new miele dishwasher. Door slams shut; will not stay open
SOURCE: Miele Dishwasher door release problem
I switched the dishwasher off at the mains and then back on again. At this point the plastic arm started making a noise like it was trying to retract so I pulled the door to help it along. The door opened and the arm fully retracted - much to my relief.
Posted on Mar 16, 2008
SOURCE: Change miele dishwasher door seal
http://www.partstap.com/ please go to this site for diagram please rate me thank you for useing fixya
Posted on Feb 25, 2009
SOURCE: the door on my miele G481 built in dishwasher won'...
hi,
what you need to do is slack off the spring tension on the door hinges. each side of the unit at the base on the plinth there is a screw with a spring symbol next to it. turn this anti clockwise to reduce the spring tension.
Hope this helps
Posted on May 24, 2010
SOURCE: 23 in. Novotronic G841 Built-In Dishwasher: the door on my miele G481 built in dishwasher won'...
hi,
you need to adjust the door tension springs which is by a screw each side of the hinges on the plinth of the unit at the front. There is a symbol of a spring to show you which screws to release. do them evenly and the door will not spring up,
Posted on Jun 13, 2010
SOURCE: Miele Dishwasher - Not cleaning
Hi, I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
xxz
Posted on Sep 29, 2010
