It has started to flash the Add Water light, when its already full and ready to brew. But it won't go off and can't start the brewing process. Help!
SOURCE: My keurig machine wasn't brewing a full cup so I
do another descale..add more vinegar....run the entire full tank of water....you must have a big buildup of scale...
SOURCE: Keurig coffee maker will not **** the water to brew
Here is a sugestion tip that will help
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Good luck thanks for voding
SOURCE: Keurig B70 brews but only brews a little bit,
Check the reservoir to see if it seems warmer than justified.
If so, then the little check valve that causes the pumping action is being blocked by a lime buildup or some other debris particle and not closing when it must to force water into the heating element.
Try pouring some plain white vinegar into the water chamber after emptying, turn the machine on briefly to allow it to start, finally, allow it to sit overnight.
Turn the maker on and pump the remaining vinegar through it without filter or coffee.
Rinse the reservoir out and then run clear water through it to remove any remaining vinegar.
If this didn't help, then the check-valve may have failed and would have to be replaced.
Although I wouldn't do it with a friend's coffee maker, I have used Lime Away instead of vinegar but I don't leave it overnight since this can damage the aluminum of the heater element.
It hasn't so far, but it can.
SOURCE: Keurig Special Edition that will not brew
all the lights are blinking its clean, descaled, filled with water and the power button and all the buttons just blink and it wont brew just had this machine less than 6 months and the machine will only quit blinking when i unplug it and yes ive tried different outlets when i plug it back in all the lights start blinking again and it wont brew i want a solution to this problem and i dont want to be sent to another site where they charge me to answer a question the $119 i payed for the thing should be enough im ready to throw it out the window im so frustrated with it
SOURCE: MY Keurig is about a year old and it won't
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
