Question about Watches
I believe the grandfather clock I was given was over wound by the previous owner. Is there anyway that I can fix this myself so that it is affordable?
I was given a grandfather clock. The face says Waltham at the bottom ans Tempest Fugit at the top, there are no serial numbers that I can find so I have no idea what year or model it is. I think the previous owner must have overwound it, because when you place the key in to wind it you cant even turn it. Is there some way that I can fix this problem myself, so that its affordable?
Posted by sgraham29201 on
Geoff
    Dedicated:
    Visited the website for 20 consecutive days.
  • 125 Answers
If you have the patience, you could try the following.
Set the pendulum in motion - this will slowly wind down the mainspring. The clock will probably stop after a few seconds. Set the pendulum swinging again as necessary, and if you're lucky the period that it ticks for will increase each time.
You will need to be patient and persevere - what you are doing is very gently releasing the tension on the mainspring.
This is not guaranteed to resolve the problem, but it won't harm the clock or your bank balance to try. Failing that, there is a mechanical fault that is causing it not to wind and you are strongly advised to place it in the hands of a reputable and competent clock repairer.
Posted on Sep 07, 2017
5 Related Answers
jdthefixer
  • 746 Answers
SOURCE: Elgin grandfather clock chimes not working
I'm not positive about this, but I seem to recall that these type of clocks have two "silence levers" on the movement. These levers are located at the upper left and upper right corners of the movement as you face the movement from the back. The movement back panel has to be removed if it has one.
If the levers are pushed toward the chime rods, they will silence the hour or musical chime, depending on which one it is. I believe the silence levers are supposed to be moved away from the chime rods so the rods can retract and then strike the chime bars.
Posted on Mar 29, 2009
David Tolond
  • 2501 Answers
SOURCE: have a waltham pocket watch in an illinois case
If you go to the web site "www.antique-pocket-watch.com/waltham-pocket-watch.html", you will find information about Waltham watches and if you read the serial number off the movement (open the back and read it off the back plate), you may be able to find out the year of manufacture.
Posted on Feb 10, 2010
Testimonial: "thank you, your information helped me identify the year and information needed"
RixsFixes
Radio Code Pro
  • 2200 Answers
SOURCE: I have a Regulator "Centurion
By your description the spring is already wound up tight and what happens is that friction is keeping the clock from unwinding and starting of its own accord.
The solution is to manually use your hand to move the pendulum back and forth for a while. It may take a few minutes, but this will force the spring to gradually unwind and kickstarts the mechanism.
Eventually after a few minutes the friction will release, and the clock should begin to work on its own.
To test this after a few minutes - once you have the pendulum started, let it go and it should continue to tick of its own accord.
Thanks for using FixYa. Please do leave a vote for the solution.
Posted on Aug 16, 2010
Anonymous
SOURCE: what year is my breitling navitimer model number 806 serial number 1011422
1965 theres a full breitling serial number list at http://www.brittons-watches.co.uk/watches_breitling_dates.htm
Posted on Dec 10, 2010
Anonymous
  • 8 Answers
SOURCE: Watch will not wind. Wound
The best solution is to lightly tap on the watch, this will keep it running until the spring is unwound enough to run on it's own.
Posted on Jan 08, 2011
I have a Waltham Open Face Pocket serial number 32560 mane in 1860, how can I find who bought it in 1860?
Unless you can trace it back through the series of owners that have held it, there is a fair chance you won't ever find that out. Record keeping in the mid 19th century was, at best, sketchy.
Feb 15, 2016 | Waltham Watches
How much was a new waltham watch.serial number wth01-032-pc21price?
Generally the PC21 Waltham watches are $25 to $30 second hand
Jun 04, 2015 | Waltham Watches
Looking for information on a Waltham pocket watch serial number 7752090
Google make model serial Watch collectors sites. You may get lucky.
Mar 08, 2015 | Waltham Watches
Find out if a watch i have is worth money
Check to see if your watch or one closely resembling it, is for sale on Ebay. This generally gives an idea of value, at least in terms of resale and value. Watches, other than Rolex and very high end types, don't have very good resale value. Of course, all of the value may be in the diamonds or 14K cases, no matter who is the maker.
Dec 13, 2014 | Waltham Watches
Tempus fugit grandfather clock manual
why the weight do not move
Dec 28, 2010 | Watches
I have a 9k waltham pocket watch and cant find any info about it, or the value of it?
A little bit more information would help the Fixya staff to address your question.
Please be as specific as possible adding as much information as you can provide will ensure a more accurate response to your question.
The below information is currently requested:
-Serial number from movement.
Mar 21, 2010 | Chase IK7A Waltham Antique Watch
I have a waltham 9k gold pocket watch, its serial number is 21772651, its 7 jewel.i cant find what its valuation is and any infprmation about it.
Pocket watch manufactured 1917-1918
RECOMENDATION:
Seek professional help for watch value.
In short, demand for antiques pocket watches are up the real question is what is it worth to you?
Keeping it in running condition increases its value to you and the next generation.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Have a waltham pocket watch in an illinois case enameled dial with a recessed seconds dial at bottom with a numeric 6. seconds on face also. can't find year or pic of this watch
Feb 10, 2010 | Chase C6A Waltham Antique Ps Bartlett...
Watches Logo
162 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
