Question about Kirby Ultimate G Bagged Upright Vacuum
Kirby runs across floor on own and is hard to pull back
When I put my kirby in drive it literally drives itself, dragging me with it, across the room. Then, when I pull it back the head raises off the floor and it is super hard to pull back.
5 Related Answers
Anonymous
SOURCE: Kirby G5
The transmission needs adjusting. Just a little fine tuning. See if you can find a repairman near you, or you can contact us at 1-866-509-1952. Thanks
Posted on Jul 16, 2007
fwadley
Farren Wadley
  • 482 Answers
SOURCE: Kirby G6 drive mode
look under the vacume cleaner and take off the cover make, shure the belt is where it needs to be, you should have a setting on the vacume cleaner that gives you an addjustment for the carpet your on, raze it up.
Posted on Nov 26, 2007
Anonymous
  • 5 Answers
SOURCE: kirby g3 tech drive
so when u pull it back it's like it's not engaged at all? then it maybe the reverse is out....with the fwd soon to follow. remember the vac is 20yrs old; & working that long? it definately served it's purpose.
depending how much money you wanna spend on it buying a new or used trans. plus labor...or just an ebay used unit.
Posted on May 12, 2009
RockyNR1
Rocky
  • 324 Answers
SOURCE: Kirby G5 rear wheels lock up completely when in "Drive"
When wheels lock when vacuum is OFF - it is normal. If it happens when Kirby is ON then there are a few things that may have gone wrong
Primary drive belt is broken or something is wrong with plastic gears. See how to check the primary drive belt HERE.
If it is fine and gears are spinning - then something must be wrong inside the transmission. Parts for tech drive are not available from manufacturer so you are on your own. It is not really complicated - 2 clutches that engage and disengage depending which direction you push the vacuum. But if something in there is broken - you have to get a new tranny. It is not like getting a transmission for a truck but it still will set you back by about 100 $.
Good Luck
Rocky
Posted on May 30, 2009
Anonymous
  • 75 Answers
SOURCE: g5 kirby's drive feature isn't working
the gears or the drive is probably worn down or is broken.take it into kirby and they can fix it for you.
Posted on Jul 02, 2009
When I push the handle forward it comes back and when I pull it back it pops a wheelie and goes forward please help
I've had that exact issue with a Kirby Diamond Edition. What has happened is that the bracket inside the machine that activates the forward and back motion of the tech drive has come out of its slot. The only way to fix this is to disassemble the machine and put it back into place.
Dec 22, 2015 | Kirby G6 Bagged Upright Vacuum
I have a Kirby G5 and need to replace the gear drive shaft, as the lever inside fell off and the shaft came out. (Common problem by the sound of it.) How do i remove the actual gearbox itself. I have...
I have never touched a Kirby vacuum
before and my wife had the same issue. The neutral/drive pedal just fell
out so I figured I would give it a shot to see if I could fix it and
quickly figured out the 3 screws in the bottom plate for the drive
unit wasn't the answer.
I was able to figure things out out after I found
a parts list with diagrams at the follow web site and address:
Vac Parts Warehouse.com
http://www.vacpartswarehouse.com/category-s/2821.htm
The two parts involved are:
13. Bracket Cam Assembly Neutral Drive
Pedal 557689A
16. Kirby Pedal Cam For Neutral Drive
G6 558499A
Here's how to get to a point that you
can get these two parts in/out of the machine.
- Remove bag and fill tube from handle
and main unit
- Remove floor nozzle assembly
- Remove the handle via the two screws
at the handle fork plate (these have loctite on them so needed a
socket wrench with torex bits to get them out).
- Remove the plastic rear scuff plate
vie the screw with the power cord anchor and screw by the Pedal Cam
For Neutral Drive. Note release plastic tab in slot in the center and
lift from the back and then over the base where the handle attaches.
I did not do this as I removed the the
power drive assembly so I could figure out how to put the dive
assembly back together. The pressed on arm that drives the cam
assembly had pulled of the pedal shaft so this also made it easier to
fish out the parts and experiment on positioning the arm in the right spot . I found the arm and a spring washer inside. Note – continue disassembly below if bracket cam assembly will not come out as it is easier to work with once the drive assembly is removed.
Remove the screw on the bottom plate that attaches the Bracket Cam Assembly and slide the Pedal Cam. Then the plastic back panel and the cam assembly should slide out if you lift up on it. Note that the screw is the only one with a star lock washer on it. Also note that this entire assembly is the only way that the parts are sold and it includes plastic back plate and metal cam assembly as. I when down the path to repair the existing assembly so I needed to take the power drive out The part was 16. Kirby Pedal Cam For Neutral Drive G6 558499A at Vac Parts Warehouse.com. The one listed on the website said it was for a G6 even though the parts listing is for a G5 so I don't know....
To continue to disassemble and take
the power drive assembly out:
- Remove the 4 screws from the Cover
Shell assembly - the metal top part. You do not need to remove the
hinged Headlight Cap that is attached to it.
- Remove the 4 screw from the bracket
assembly that has the handle attachment and forward/reverse switch.
It attached by two wires. I only disconnect one and swung it to the
side.
- Snap off the the on/off switch and
disconnect from the Actuating Rod Foot Pedal to Power Switch.
- Remove the 3 screw from the bottom
plate of the power drive assembly.
- Remove the drive belt.
- The power drive assembly will now
drop out the bottom.
I just put the spring washer and arm
back on the shaft and reassembled. I'll see how long that lasts
before before buying the new part. Update: this fix did not last long. Use red Loctite or super glue to attach cam to shaft so it doesn’t pull out if you want to avoid buying the new assembly. Note that the cam must be aligned so that when the neutral side is pushed the cam will stop in the detent to hold it in place. Must be reassembled in the drive position as that is the default for the drive assembly.
Have fun.
Aug 08, 2010 | Kirby G5 Bagged Upright Vacuum
When in drive mode the vacuum moves by itself
There's nothing wrong with it. It's like an automatic transmission to help move the kirby across the floor. It is supposed to make vacuuming easier.
Mar 28, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Kirby sentria shampooing not right
make sure u put the exact/right instructed amount of soap in the tank.....after each room, wash & clean tank filter. open tank all the way.....pull back slowly. if too much foam...adjust tank knob.
May 10, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Kirby g3 tech drive
Mar 31, 2009 | Kirby Generation 3 Bagged Upright Vacuum
The vacuum drive makes a wining sound
Does It make the noise all the time or only when the machine is moving. If it does it only when you push the vacuum that noise is normal. The older Kirby transmissions make a whining noise when pushed.
Mar 24, 2009 | Kirby G6 Bagged Upright Vacuum
Kirby G6 drive mode
Nov 26, 2007 | Kirby G6 Bagged Upright Vacuum
Kirby G5
nuetral/drive, the g series has a power drive motor for the back wheels
May 13, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
94 people viewed this question
Top Kirby Vacuums Experts
Paul Bade
Marvin
Marvin
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
