Question about Technics SL-1200MK2 Turntable
Hi, I have just bought a second hand Technics SL-1200 MK2 and it looks great overall. There is one problem though with the pitch. When I want to slow down the speed a bit, the platter starts to spin a little bit faster instead, until I have reached over -1. At that point, the turntable reaches a second zero and from there on slows down normally. Do you know if this problem can be fixed easily?
Posted by Johan De Weerdt on
  • 1 more comment
  • Johan De Weerdt Feb 05, 2013
    I would like to know, since there are 2 zero points, wethere the problem can be solved by calibrating the zero point manually. Is such an action useful when the second zero point is situated at -1 and not at +1 for example?
    Hi all, I have found out what the exact problem is with the pitch. Its zero point is not situated at 0 but at -1. Is their a way to get the zero point back in the middle, at the green led light?
  • Erik Wolbrueck
    Erik Wolbrueck Oct 05, 2017
    Yes there is a simple way. There’s an adjustment inside that you can do with the Phillips screwdriver. Take a look at my answer down below
Erik Wolbrueck
    Habit-Forming:
    New Friend:
  • 23 Answers
Your problem Is more than likely one of two easy to fix things. First we'll try the easiest. that would be reset the centerpoint of your pitch controll. All you need is a Phillips screwdriver and a little time and this picture: Apparently the picture is too blurry to read so let me give you the link: http://www.deckdoctor.com.au/TECHNIC%20SL1200%20PCB.pdf
you don't have to worry about all the technical stuff really it's just started look at the strobe lights and slowly turn the screw as you move the slider back to Center and make sure you bring this keep the strobe stable. if that doesn't fix your problem, then you do have to worry about the complicated stuff. If you are not familiar with all of that, I would suggest just replacing the pitch control. it's cheaper than paying what it would cost you at a repair shop and very straight forward. You don't even need to saulder. They don't cost very much and the part number is right there you can get one on eBay for pretty cheap. Good luck
Hi, I have just bought a second hand Technics SL-1 - 1a794108-835c-4a1b-a9e5-c7230835786f-4l2c040jch4zrjjifkowtvts-4-0.jpeg
I’m happy to help further over the phone at https://www.6ya.com/expert/erik_149c4c1c216e42f2
Posted on Oct 05, 2017
5 Related Answers
fire sine
Keith Seekwhensir
  • 382 Answers
SOURCE: Technics 1200 MK2 displaying irregular speed to include dragging and slowing
It sounds like the pitch slider needs to be replaced...
Mikey's Hook-up
88-90 North 6th
Brooklyn, NY 11211
Cover insured UPS charges both ways and you will get sorted.
Posted on Oct 28, 2007
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: help for technics 1200 MK2 and 1210 Speed is too fast
On the 1200MK2 the pitch control slider is for just that purpose. Disregard the 0 setting and use the illuminated strobe marks on the platter to adjust to nominal speed. When they appear to be motionless you are there. The control on the 1210 may be a knob but the same principles apply.
http://en.wikipedia.org/wiki/Technics_SL-1200
Posted on Apr 04, 2009
Anonymous
  • 515 Answers
SOURCE: Cannot adjust speed on a vintage Technics SL-B30 Turntable
More than likely it is a faulty drive IC (Integrated Circuit). If so, your out of luck, because most parts for this unit are discontinued, with the exception of the belt.
There really isn't much else you can do. Will probably cost too much to repair, if you can find someone who can repair it.
Sorry couldn't be of much more help.
- OPTiC
Master Tech
Digital Analog Therapy
Technics Parts : Turntable Repairs
Posted on Aug 30, 2009
micmor100
Morne Olivier
  • 257 Answers
SOURCE: just bought a new technics sl-1200 turntable and
You will need to check your belt for wear. Lift felt on platter and check belt tension. It may need replacing. To replace, simply lift platter section of the unit, taking note of the belt position. replace and your problem will be solved
Posted on Aug 18, 2010
STYLUSCITY
Styluscity
  • 271 Answers
SOURCE: SL-1200 Turntable: I own two Technics SL-1200mk5 turntables. My probl...
Hi, could just be platter not fitted hard down on spindle. I suggest you remove the platter and place it upon a dead flat surface to check to see that the platter is flat. If it is flat refit to turntable ensuring it is hard down on the spindle. If bent discard and replace with new platter.Platters can be ordered for all model 1200/1210 from [email protected]
Posted on Sep 13, 2010
Technic 1200mk2 pitch problems
Check for bad solderings on Q201 and surrounding areas.
Resolder IC101 and IC201. If that doesn't help, Q2 and Q3, both 2SD637R, could be broken. If that doesn't fix it replace the electrolytic capacitors. Cheers john. Styluscity
Mar 03, 2012 | Technics SL-1200MK2 Turntable
SL-1200 Turntable: My brand new Technics 1200 MK2 sounds wobbly when ...
Try plugging it into a different power point. The problem is with the power supply fluctuating. You can eliminate that with a UPS, here is a link to wiki http://en.wikipedia.org/wiki/Uninterruptible_power_supply
[email protected]
May 10, 2010 | Technics SL-1200 Turntable
Pitch wobble 1210
i had my decks fixed by these guys they are in london.
thier websites is www.technics1210repair.co.uk
they do technics turntable servicing
check them out.
im only spreading the word due it i had my decks fixed their and i am so pleased im telling everyone so they can get the same service i did, rather than paying over the odds at some **** toster repair shop.
alan
Apr 23, 2010 | Technics SL-1210 Turntable
Pitch Control issues on Technics 1200 mk2
The pitch pots have been altered.
there located under the platter & cover on the main circuit board.it's a peace of **** to sort them.
if you help e-mail me [email protected]
Jul 20, 2009 | Technics SL-1200MK5 Turntable
Help for technics 1200 MK2 and 1210 Speed is too fast
Apr 04, 2009 | Technics SL-1210 Turntable
1210 mk 2 pitch
Doubt it, ive heard of this problem before, usually people buying them second hand and the answer has always been get them repaired professionally, i dont know the reason for them doing it sorry.
Jun 10, 2008 | Technics SL-1210 Turntable
Mikey's Hook-up
88-90 North 6th
Brooklyn, NY 11211
Oct 23, 2007 | Technics SL-1200MK2 Turntable
Technics SL-1200MK2 Turntable Logo
216 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
