All cash registers can be programmed NOT to open on the No Sale button. It is a way to open up ***** and under-ringing / pocketing the money handed over by pressing N/S instead of an amount.
Royal Consumer Information Productshttps://www.royal.com > cashreg > Instruction ...
DOC
Royal's helpful "Quick Start" program (Page 12) will provide you with the most basic programming options for the operation of your new cash register.
Replacement Journal Paper Roll Spindle: 105...
Protective Keytop Cover: 013221
Item Description: Part Number
Several people before you have tried and tried to obtain this document and sadly i dont see any technical support from royal regarding this product and so thusly, the existence of a digital manual does not exist. If you go to royals website and look at the manual for the dm 7000, they most likely adopted a similar structure of use for their newer devices. But even for that product there is no real manual.
You can try and navigate through the device and hopefully find a help section as most devices that are this difficult to operate require some training on how to use them.
I also have a Royal dm80 personal organizer that has no batteries. I need the numbers off the batteries so I can get mine to work. I would be happy to mail you a copy of my instruction book if you could tell me the type of batteries I need to buy. thanks. keokih/
You will need to remove the entire chassis block as outlined in the manual. DM stands for digital board. It will be listed in the manual as PWB DM its sandwhiched in between other boards inside the chassis . Which is actually a metal box that will need to be disassembled then each board removed to get the DM . The DM is usually the bottom board. I dont have access to the WD65833 sertvice manual, but I am famillar with it. The DLPs are all simallar the entire Chassis block needs to be removed. Hope this helps if you need more info, let me know.
