Some of my channels have no sound whatsoever and some are in spanish, the others function just fine....Is the problem my converter box or my tv?
SOURCE: Magnavox converter box
call the number on the back of the remote, it is 1-800 annd they can trouble shoot for you.
SOURCE: Low Sound
Find out if there is a volume control for the converter box and adjust accordingly.
SOURCE: cannot keep all channels on tv
When you say you "lose" channels, you probably mean there's no signal there anymore but they are still in the channel memory. This is normal if you have a rotatable antenna. You need to mark the rotator (or just keep a chart nearby) with the heading for each channel.
If you mean you're losing channels from memory when rescanning after turning the antenna, the only solution I can offer is to record the channels found (and their signal levels) after scanning a direction. Then change directions and rescan. See what new channels have been found, what have been lost, or how signal level has changed on common channels. Then you can manually add whatever you need, and you'll know what direction is best for each. It's tedious, but you should only need to do it once.
SOURCE: Converter Box Problem
That just means that stations you can't pick up while the box is on are not broadcasting digital signals yet. Most will be after February.
SOURCE: tv as of sun night says no signal....converter box was working
Re scan your channels. Analog is gone and alot of channels have moved. Just re-run the setup on your converter and it should be fine. The channel numbers may change, but the programming hasn't. Hope this helps
