Question about Sony Playstation 3 (40 GB) Console
PLAYSTATION 40GB BLUE LIGHT TURNED OFF
Hi, the blue light at the front of my ps3 which is next to the green light, does not light up. The green light is ok, it is just the blue light. Why is this ? My ps3 makes a clicking noise also, if that is of any help and this is before i put the CD as well as after. (basically, as soon as i start my ps3) please help me , much appreciated thanks.
Posted by SGSG on
2 Related Answers
Anonymous
  • 41 Answers
SOURCE: red light goes green but no blue light
the blu light means it is accessing a game/ blu ray
Posted on May 04, 2009
Anonymous
SOURCE: The green light on my ps3 works but my blue 1 doesnt show up
I had kinda the same problem, but my ps3 was able to get to the home screen. I never tried the problem out on a ps2 game, but when I put anything BlueRay into the system, I would also get that blank, blue AV screen. Because I was able to access my home screen, I looked around and found that I had corrupted data on my system. Now, I'm not sure how to get you back to your home screen, but if you're ever able to, the only solution that I found was to wipe the hard drive of the corrupted data, by going to the Game option on the home screen, then scrolling down to either Game Data Utility or Saved Data Utility. That's where you'll find it. Unfortunately, this will mean you'll have to wipe your entire hard drive of all your saved data.
I know it sucks, but I hope this helps...
otherwise have people look at it.
Posted on Aug 26, 2009
Hi console stopped working. when turned on light goes blue then green then red
sorry to say but it might be the RLOD meaning get new parts and charge you lots or get a new PS3
Jun 07, 2010 | Sony Playstation 3 (PS3) Console
My friend's PS3 has some light of death we are guessing! It will turn green, then will turn blue & green, then it turns green & yellow, then it turns blue & yellow. Then just yellow followed by...
This is known as the yellow light of death (ironic i know because it blinks a red light). This is caused when the unit overheats causing solder on the board to melt and bridge(connect). Once this happens it shorts out the board causing the error you have now. Contact Sony and see if the unit is still under warranty.
Feb 10, 2010 | Sony PlayStation 3 40GB System
My ps3 just stop working, when i try to power it up, the green light turns on followed by a blue light, then yellow
The Yellow Light of Death (YLoD) is a fatal error that occurs when your Playstation 3 (PS3) overheats.
The welds that connect vital components to the system board soften and break.
It's manifestation - a blinking yellow light on a PS3 that refuses to do anything else.
You have 2 options at this point:
  1. Return the unit to Sony.
    if your PS3 is still under warranty, the fix will be free; otherwise, Sony will charge a flat fee of $150.
  2. Fix it yourself for less than $80.
    This list contains the necessary tools and components to effect your PS3's meteoric rise from it's YLoDic grave as set forth in this free YLoD Repair Guide.
Feb 09, 2010 | Sony PlayStation 3 40GB System
Green light comes on then blue then yellow then
hi..
the only way you can fix this is by sending your ps3 to sony
and the disc...
thank u
rate me!!
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
TV Blank when powering PS3
When tv and ps3 backswitch turned on hold down the front power button when off until the ps3 has done a double beep after the intitial beep and wait for a max of 1 min and initial set up screen should appear
Apr 20, 2009 | Sony Playstation 3 (PS3) Console
PS3 light turns GREEN, w/ blinkin BLUE, to YELLOW, to flashin RED
it is fried and needs repairs if you break the seal by trying it yourself you void the warrany
Mar 15, 2009 | Sony Playstation 3 40GB System Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (40 GB) Console Logo
26 people viewed this question
Top Sony Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
