Question about Audiovox FPE2306 23 in. LCD Television
The TV will not turn on all the time, why not
The TV will not turn on at all times
Posted by Tom Faas on
Lucas Rodriguez
    New Friend:
  • 16 Answers
Make sure the wires are plugged correctly so that the TV is powered. Try to turn it on by pushing the ON button instead of the remote. Since when is it not turning on?
Posted on Feb 03, 2013
What might be the problem with tv making popping noise when turned on
you must have a wire ( sound plug ) not connect properly ,
sometime those plug loose with time ,
when powered the make connection and those sound happen !
Apr 05, 2015 | RCA L32HD31 32 in. LCD HDTV
I have a tv Sony Trinitron XBR. It does not turn on; the LED red light blinks 7 times.
Common problem on those. It has deflection stopped. I.C. on deflection board. Need shop to repair.
Nov 23, 2014 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
No picture just a standby red light flashing
tv won't turn on red blinks 5 times , some times it will turn on like every 3o04 days
Aug 06, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Samsung SP50L6HD Tv turns it's self off. Time
sir it may happen if the auto off option is enabled and the timer is enabled........... check for this options if they r and enabled then disable that........... or give your tv to the service shop and check for any problems
Jul 20, 2009 | Samsung Televison & Video
Tv turns off randomly but turns on after 35 seconds.
How old is this TV and when did you replaced lamp last time?
Jun 09, 2009 | Panasonic Televison & Video
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
May 31, 2009 | Sony KV-27S42 27" TV
My lcd tv takes a long time to come on
When the TV stays on protection with the led on and blinking for a while , then suddenly turns on, that is oftem because of a faulty power board.
Nov 16, 2008 | RCA LCDX2328WD 23 in. TV/DVD Combo
Sony KP-FX432M91 TV 10 blinks
my sony kp-fx432m91 has a 10 blinks problem. it has no pictures but has sound that goes off after 5 seconds please advice on what to do.
my email address is [email protected]
Oct 31, 2007 | Sony KP-FX532M91 TV
Audiovox FPE2306 23 in. LCD Television Logo
85 people viewed this question
Top Audiovox Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
