It starts fine and washes but when it's time to pump the water out all you hear is a loud noise like it's trying to work. How had is it to replace the pump? Does anyone know how to take it apart and the best place to order the part from
It may just need cleaned. You haven't given me any info on your machine so i can't tell you how, but you can go to YouTube type your washer name or type (front loader or top loader) and the words, "...drain pump repair" and you should get a video that matches your machine. You may have to watch a few before you find yours but you should have no trouble. Let me know if you do.
I have a front loader LG TROMM vm1812cw. I did go onto youtube and found videos to she me how to do it. Thank you I think I'll order the part and try to fix it myself; if I run into a problem I'll hand the job over to my husband.
Don't order the part until you've checked that it's not just a clog. If it's noisy there is probably a jamb that can be unjambed. Save your money until you know for sure. Good luck.
I cleaned out the filter and vacuumed the hose to check for clogs already and that didn't help.
SOURCE: Nasty Noise when Maytag MAH-24 pumps-out
Unplug the machine. Tip the machine back. Take the plastic cover loose from the bottom front of the machine. There are 4 screws on the right front side of the machine that form a square. Remove those and take the spring clamps off the pump hoses and wire connector. Whatever water that is in the machine will come out, have a bucket or shop vac ready. The coins or other foreign objects that are in the pump can now be removed. Hope this helps
SOURCE: Washer still wont drain, even after cleaning drain pump line
"F02" is a Long Drain error. If you have managed to verify that the drain lines are clear from the tub - to the pump - the the wall, then this usually indicates that the pump has failed. It can be common for this pump to make noise and still not work.
Just to be sure: Is water running freely form the tub to the drain line when you drain the water? If not, make sure you double check the line from the tub to the pump. Is can be common for small articles of clothing (i.e., wash cloth or underwear) to get caught in this area and restrict water flow. Don't ask me how these items get between the wash tub and basket, but I have seen it happen.
The pump is usually sold as a complete unit and can be found at searspartsdirect.com. Just type in your model number and the part will be listed under the "Pump & Motor" heading. It is listed as item #10 (part #8181684) and sells for about $71.00.
This is a fairly simple job that you can accomplish yourself if you feel inclined to do so. If you click on my profile and look under "Tips and Tricks", I have step-by-step instructions posted on how to replace a drain pump like yours. If you cannot find the information you are looking for, please post back and I will assist you further. I hope this answers all your questions.
SOURCE: Screeching Noise From Fisher & Paykel GWL115 Washer While Filling
if its while filling may be water pressure try turning tap down (hot)
SOURCE: zanussi washer just keeps on trying to drain
this is the electronics on the machine reacting to a fault .the electronic has detected an electrical component fault .for example a motor gone short circuit you can only find out what by testing the components with a suitable test meter or by acessing the machines own diagnostic facility and retrieving the error code .if cant test with a meter you need the manufacturers service engineer
SOURCE: Fisher-Paykel washer pump noise & some water left in tub
Lube the brass bearings on the motor. For some reason the bearing on the bottom nearest to the cooling fan will start to whine. I would guess because it's kicking dust up around the unit. I used a lube that will hold in place. Lube between the bracket that holds the motor together and by the fan. The noise should stop. I also suggest you lube the top bearing as well. The lube I recommend is a Silicone paste type.
