Question about Technics SL-1200 Turntable
Technics 1210 mk2 humming
Buzzing noise
Posted by steve_and229 on
Styluscity
    Champion:
  • Technics Expert
  • 271 Answers
Hi, it needs to be earthed to your mixer or amp. Cheers john
Posted on May 03, 2013
5 Related Answers
Anonymous
  • 515 Answers
SOURCE: technics 1210 mk2 problem with pitch and lights
Check that your voltage settings are set correctly. This is located underneath your turntable platter. If you remove the slipmat, you will see 2 holes on the metal platter. Rotate the platter till you see the voltage switch, located @ the 9'o'clock position. Make sure it's set to your correct settings (N.America = 115V / Euro = 220V). If not, you will need a flat head screw driver to switch it. Before you switch it, make sure your unit is off and unplugged. After you swich it, it should be ok.
If your still having issues with the speed and the pop-up light, then there is something seriously wrong, and will need to be checked by a technician. Sometimes a resistor or IC will go bad, causing the speed issue, but for the pop-up light - that's usually faulty wiring generally caused by an incorrect replacement.
Did you buy this new or used? Have you had this serviced recently?
- TWEAK AV LAB
The ORIGINAL TURNTABLE Technicians
Posted on Dec 01, 2007
Anonymous
  • 515 Answers
SOURCE: How old is my Technics SL 1210 Mk2
Here's some information for you. Since your unit is a SL1210MK2, it may be harder to determine the age of the unit:
It is possible to tell the year (and the month) when the SL-1200 was manufactured from the serial number on the back or bottom of the turntable. SL-1200 serial numbers are in two different formats, depending on the date of manufacture. It isn't exactly possible to determine the decade in which the SL-1200 in question was manufactured, as the serial number contains only the last digit of the year. If the year digit is 8, the turntable may have been manufactured in 1978, 1988 or 1998. If the year digit is 0, the turntable may have been manufactured in 1980, 1990 or 2000. One rule of thumb is that old-format serial numbers belong to SL-1200s manufactured during the 1970s and 1980s, while new-format serial numbers belong to SL-1200s manufactured during the 1990s and beyond.
Old-format serial number: NHOJF20765 (SL-1200 manufactured 1982)
The first digit shows the year when the SL-1200 was manufactured. These serial numbers contain no indication of the month of manufacture. It should be noted that serial numbers in this format contain no letters following digits.
New-format serial number: GE4FB001154 (SL-1200 manufactured June 2004)
The first digit shows the year when the SL-1200 was manufactured, while the month of manufacture is indicated by the letter following it. Months are coded as letters between A and L inclusive; A indicates January, B indicates February, and so on.
In addition to the above, all the SL-1200MK2s from the 70's and early 80's have a 4 inch diameter plate where the RCA and ground wires enter the chassis in the rubber base of the unit. The later models have a smaller hole through which the wires enter the unit.
TWEAK A/V LAB
www.DJPROLAB.com
Posted on Apr 10, 2008
Anonymous
  • 515 Answers
SOURCE: Technics Sl-1210 MK2 GOES MONO
Check to make sure you have a nice solid connection on your tonearm from your cartridge. The problem is either your tonearm or your RCA (red/white) cables.
Neither are easy repairs, unless you have soldering skills/experience. The tonearm replacement is the more difficult and more costly of the two.
Parts for the unit can be purchased HERE. If you have any questions about testing your unit on the exact cause, please feel free to give our TECHS a call - they are available 24/7 for your convenience @ 1.866.668.1596 ext 1
- DJ PRO LAB
www.DJPROLAB.com
Posted on May 13, 2008
Anonymous
  • 6 Answers
SOURCE: technics sl 1210 will not start up
did you ever open the turntable. It sounds like the on/off switch is bad. Remove the platter and screws with a phillips screw driver and just make sure the connections are in place. make sure you disconnect the power first. let me know what happens afterwards.
Posted on Jun 03, 2008
freetek
Steve Allison
  • 5569 Answers
SOURCE: Technics 1210 MK2 - unstable/uneven speed problem
Since this is a direct-drive turntable, it isn't a slipping or stretched belt. You will need a technician with a couple pieces of equipment and some experience/training to find the source of the problem. I suspect the part(s) will be the minor cost of the repair.
Posted on Sep 07, 2009
The e t c is buzzing what is causing this
ANSWERS: Oil Loss, Buzzing Noise, ETC. - Nissan Forum ' Nissan Forums
forums.nicoclub.com/answers-oil-loss-buzzing-noise-etc-t323273.html
Mar 20, 2008 - 3) Yet another buzzing, rattling or whinning noise. If you own a Quest van, Maxima, Altima 3.5 and some Z/G/FX vehicles, and get a loud ... Mysterious no-spark situation with a buzzing transmission
Mar 31, 2013
ABS brake fault light on, buzzing sound
Feb 7, 2011
ECU making loud buzzing noise
Oct 6, 2009
Buzzing noise under the hood towards the back of the engine ...
May 8, 2008
More results from forums.nicoclub.com
Buzzing noise at 2000-3000 RPM - Nissan Forums : Nissan Forum
www.nissanclub.com/...nissan-altima.../128490-buzzing-noise-2000-300...
Oct 28, 2003 - 6 posts - ‎3 authors
The "buzzing noise"; I can tell that I am not alone in having this problem but has someone figured out ... I fit does, that eliminates the brake rotors, tires, wheelbearings, CV's etc. ... BUT with an Altima it is probable the pre-cats. Loud humming noise when driving
Aug 29, 2009
Noise when accelerating
Jul 21, 2009
engine noise/whine - 05 3.5SE
Nov 17, 2006
My altima has a humming noise under my hood
Jan 17, 2005
More results from www.nissanclub.com
Jan 05, 2016 | 2000 Nissan Altima
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
BUZZING NOISE
Is this noise a motor buzzing noise? If motor has power but the start circuit is not energized, then the power through the run winding cannot start the motor and may make a buzzing. Need to address the type of buzzing and if the motor, then check motor circuit.
Jan 08, 2014 | Hoover Dryers
Danfoss 103 timer is making a constant buzzing noise!!...everything's works fine but I want to stop this buzzing noise. Any actions I should take or advice would be much appreciated. Thanks.
How much wattage is going through the timer and what is its rated load max? try unplugging whatever is plugged into it and see if it stops but if you exceeded the max load might be damage to the internals which can cause that buzz.
Feb 05, 2013 | Hardware & Accessories
Transmission buzzing
Click this link below to troubleshoot the buzzing noise problem from transmission:---http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
--------This will help.Thanks.
Feb 19, 2012 | 1999 Toyota Camry
Buzz noise behind dashboard 2001 GS300 LEXUS
The buzz noise is probably coming from the airflow controls turned off but being stuck in a particular mode such as vents and feet mode or winshield and feet mode, creating a buzzing noise while it is turned off. To stop the buzzing noise turn off the aircondition / heat by pressing the off button, next press the mode button for the fan controls to make the picture point to face only not feet or winshield, this should stop the noise.
Oct 01, 2010 | 2001 Lexus Gs 300
Buzzing noise, just replaced the lamp, pulled and ...
The colors wheel was defective,was spinning off of it axis that was where the buzzing noise came from.Now the colors wheel it totally dead,that why u not hearing anymore buzzing noise,and not getting a picture.Hire a tv repairman for this job.Replacing DLP tvs colors wheel is not easy,if u have no machanical's skills and never done this before.
May 21, 2010 | Samsung HLN5065W 50" Rear Projection...
Toshiba 36zp18q buzzing noise.
Humming sounds come from the power supply and buzzing sounds come from other circuitry. Most likely a capacitor somewhere.
Feb 18, 2009 | Toshiba 36A40 36" TV
Repetitive Buzz
Need to check the cooling fan.
-- open the back cover & unplugg two of cooling fan socket(black & red wires or yellow & red wires)
If the noise still remaining, need to exchange the color wheel.
Jan 29, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Technics SL-1200 Turntable Logo
671 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
