Question about Samsung RF265ABBP (25.8 cu. ft.) Bottom Freezer French Door Refrigerator
Lights not working
While I was cleaning out the refrigerator I heard a pop and now neither of the lights at the top will turn on. I confirmed the bulbs are working in another appliance. the freezer light is still functional and there are no error codes on the panel
Posted by TJSD on
car253
    New Friend:
    Problem Solver:
  • 7 Answers
Maybe those light bulbs are not for a refrigerator appliance. Go to the local Home Depot and ask for refrigerator light blubs.
Posted on Feb 05, 2013
5 Related Answers
Anonymous
  • 59 Answers
SOURCE: Samsung RL36SBMS Bottom Freezer problem
LOW HUMMING NOISE COULD BE THE COMPRESSOR CHECK CAPACITOR
Posted on Aug 19, 2009
Jacques Alexandre
  • 183 Answers
SOURCE: replaced 30 watt bulb in
Either the door switch or the light socket is bad. Disconnect the refrigerator and pull the switch out and test it with an ohmmeter for continuity.
Posted on Jan 06, 2011
Testimonial: "thanks"
walterkunesk
Wally Bald Guy
  • 683 Answers
SOURCE: Refrigerator is not keeping food cold. Temp is set
Most refrigerators have the evaporator in the freezer and use air flow to cool down the refrigerator compartment. Can you tell if the defrost cycle is working, IS there ice on the evaporator. Can you defrost it. Try taking it off the power freeze cycle and also power cool cycle. When you cleaned underneath did you find a pan that had water in it. sometimes the drain clogs up and the condensate just sits in the freezer and refreezes the water, this acts like a blanket and slows down the cooling in the refrigerator. see if you can look at see if the drain is clogged, this may be your problem. You can get back to me and i will see if i can help you. thank you. and a rating would be helpful. thank you. wally
Posted on Mar 15, 2011
Henry Leunissen
  • 142 Answers
SOURCE: The model # is RF25VABWP - I was cleaning the
The lights will go off after a certain time period; that is built into the control. But if the lights never worked even after the door has been closed for a time, it is probably the light switch, which is in the "throat moulding" or "breaker strip", whatever you want to call it. That it the plastic strip surrounding the door when in the closed position. That should be under warranty.
Posted on Jun 08, 2011
caroldon
  • 17130 Answers
SOURCE: I have a Samsung refrigerator
Please check the door switch and the bulb holders, in some cases it can be due to loose connection or a faulty switch on the door, The failure of the bulb is another issue but the main subject is how you can check and remove the bulb.
Please check on the link below for tips and spares:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2/280/common-fridge-and-freezer-faults.html?k=#nolight
Posted on Jul 19, 2011
No power. unit dead.
may popped the breaker would have to remove grille and control panel to confirm. unplug microwave first
Nov 05, 2013 | GE JVM1630 Microwave Oven
Refrigerator very warm and won't cool , freezer working but...
if the compressor wsnt running it wouldnt get cold the real question is is there ice in the freezer on the back wall
Jun 02, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
While oven was on, heard loud pop. oven no longer
Sounds like your element wire shorted out on back of unit.Try removing back panel and cheak wire on bake element .MAKE SURE YOU UNPLUG OR TURN OFF BREAKER.Hope this helped you out:)
Mar 11, 2010 | Kenmore Kitchen Ranges
No power
More than Likely one of the relays burnt on the EOC, you will need to replace it
May 21, 2009 | GE 30" Self-Cleaning Freestanding Electric...
Electric Dbl Wall Oven-loud popping noise at end of self clean
Bill ,i dont suspect the control unit is the problem im going back to the loud pop you heard I would say the pop you heard was one of the elemants blowing and that the reason the the breaker tripped if you say the clock,timer and light functon are ok it more so points to an elemant in most cases when an elemant blows it breaks the circuit .but the other componants also work when you reset the breaker i think in this case bill i would call a electrician it needs testing,sorry i could not help this time bill,but do not hesatate to contact me if i can help you again.adrian
Feb 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Bake or broil does not work
if an element itself had shorted it would not stop the other from working and you could inspect each element and see blistering as evidence.the pop you heard has to be in common with both elements but not the cook top[burners]so thats going to be the wiring in the back of range, or switching,[thermostat,clock timer or oven selector switch,depends on which model you have]you will have to pull range and remove back pannels.you will find an obivous burn't connection.too repair all new connections must be clean and tight,or will burn again.
Jan 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Dec 16, 2008 | Frigidaire FEF366EC 30" Freestanding...
MAYTAG MBB1952HEW - Bottom-Mount
I have this exact problem...was there a solution? Frost is causing bottom freezer door not to work, when I remove the frost, the light comes on. The gasket looks fine. Any Ideas?
Aug 14, 2008 | Maytag MBF2556HEW / MBF2556HEB /...
Samsung RF265ABBP (25.8 cu. ft.) Bottom Freezer French Door Refrigerator Logo
129 people viewed this question
Top Samsung Refrigerators Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
