This is model KUDE70VSS2. It is stuck on the heat dry setting and when I push any other button the heat dry button light blinks and the other buttons don't respond. It seems to be locked on this setting. The word lock is actually on the button which makes me wonder if there is a way to unlock it.
Could the model number actually be KUDE70CVSS2? All of the Kitchenaid dishwashers listed on their site have 4 letters between the numbers.
If this is the right model, then the Heat Dry/Lock is probably indicating the Control Lock is active. Hold the Heat Dry button for at least 4 seconds.The Control Lock which prevents anyone from changing or starting the dishwasher by accident; press and hold for 4+ seconds to toggle it on and off. You can find the manual for most Kitchenaid appliances through their support site: https://www.kitchenaid.com/customer-service/manuals/ . The direct link to the owner's manual for the KUDE70CVSS2 is https://www.kitchenaid.com/digitalassets/MLPDF/User%20Instructions%20-%20W10208709.pdf . The use of the Control Lock feature is on page 5 of the manual.
I hope this helps.
(I searched for the KUDE70 to find the likely model number for your dishwasher.)
SOURCE: Kenmore 24 in. 17842 dishwasher heated dry light blinking
you have a shorted keypad. you will need to replace it. you can get parts at jacobyparts.com
SOURCE: My Whirlpool Quiet Partner 111
Disconnect your circuit breaker for 20 minutes and then reset. It should reset your dishwasher.
SOURCE: I have a Kenmore Ultra
Hi
Thanks for using FixYa. To resolve this issue try
to press and hold the NO HEAT DRY/Air DRY button for 15-20 seconds, if this won’t
resolve the issue then you’ll have to replace the control panel. Please do
accept the solution if the issue is resolved or post a comment for further
assistance.
Thanks
Rylee
SOURCE: My dishwasher DU1050 is stuck on Lock and I've
Hi! cccole
Dishwasher may be in bind. remove kick plate and make sure adjusters are not putting case in a twist, or pressing unit to tight to top of cabinets.
InMrFixIt.
SOURCE: Can't get the lock on button to go off by pushing
Hi First make sure that nothing is blocking the drain pump
assembly located inside the lower front panel of the dishwasher. If the issue
returns after its cleaned then try to reset the dishwasher control by pressing
the NO HEAT DRY button and hold it for 35 seconds, if its still not resolved
then it means that the control board has gone bad and should be replaced. Hope
this helps...please post back for further assistance. Daniel
To prevent children from accidently changing the
dishwasher cycle or starting the dishwasher, lock
the dishwasher controls by pressing and releasing
the DELAY START pad (some models) or the AIR
DRY pad (some models) for 3 seconds. An
indicator light on the lock graphic pad will illuminate
when the controls are locked and no new
selections can be made until the lock is released.
To unlock the controls, press the DELAY START
pad or AIR DRY pad until the indicator light goes
out
