My MSI wind u135 won't turn on it starts to charge
Posted by youngma04 on
pankaj rautela
    Genius:
  • 1,252 Answers
Remove the battery then try to on it
Posted on Feb 03, 2013
5 Related Answers
Anonymous
  • 63 Answers
SOURCE: hi i have an msi
The moon icon usually indicates that your machine is in SLEEP mode. Try closing and opening the screen lid. If not, there might be a problem with your laptop waking up from sleep mode. Try holding the power button. This will turn it off. Turn it on again by pressing the power button once more. Hope this helps! Have a nice day.
Posted on Apr 11, 2011
Anonymous
  • 119 Answers
SOURCE: have msi lap top vr601x model when try turn on by
the half moon indicate an sleep mode when you open your laptop the sleep mode is already activated thats why it goes to shutdown reason is your sleep mode key is grounded try to consult it to your your dealer
Posted on Sep 17, 2009
aroracaty2
Monika Arora
  • 503 Answers
SOURCE: ive got a MSi U135 with built in web cam how do i ...
You are sure you have a webcam, right? In the manual, it shows the webcam as optional. Is a webcam listed on the box, the white label with the serial #, that the netbook came in?
If you do have one, you have to turn it on first. The manual, pg 2-9, tells you how to turn it on. Press the Fn+F6 keys at the same time(or while holding down the Fn key, press the F6 key) to turn the webcam on and off.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on May 22, 2010
Anonymous
  • 9 Answers
SOURCE: hi..greetings to all kind technicians here..kindly
Have you tried pressing the Fn and the F11 key at the same time? this allows you to turn on and off the wireless...chances are it was disabled by default.
Here's a quick guide on the function keys:
Posted on Mar 05, 2011
Testimonial: "thanks a lot sir...u did a great guide..More power and God Bless..now its working"
Anonymous
  • 228 Answers
SOURCE: my msi u210 stays black
Hi malbasmunchy,
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left from the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F4 or F5, depends on the key designed on the keyboard to toggle between displays.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the laptop not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Posted on Jun 20, 2011
Testimonial: "thank"
How to install built-in cam?
Try the MSI website, Support section. and download the drivers from there.
1helpful
Can an msi u100 screen be used as replacement on a U135 dx?
As long the pc and the new monitor has a VGA cable it works.
MSI Wind U135 wont connect to wireless internet
Try disabling ALL encryption and MAC filtering on the router and see if you can get it to connect that way. This is most frequently a mis-matched encryption or MAC address issue.
My MSI U100 Netbook won't charge. I purchased a new battery, and it still won't charge. So the battery was not the issue. Can the the AC power cord go bad as well and I should replace it? Or is...
Yes the AC Cord does go bad , you can also look at the power jack at the back of the Laptop to see if it is loose when you plug it in. I always start with the plug they are usually cheaper than a battery.
1helpful
Hello i have tried on several occasions to activate the blue-tooth on my msi u135 DX but it does not work. it says i press fn and F11 together but it only brings WiFi. please help me. thank you.
If you are using windows 7, there is probably a wireless assistant program installed. Within that program you will have options for starting wifi only or bluetooth only or both. Select both and you should be fine.
I don't know how to turn bluetooth on on my mis wind u135.
Hi
It may be activated by pressing the FN+F11 keys its possible that two different circles will appear on your screen one for the wireless and one for the bluetooth
hope this was usefull to you
many thanks
5helpful
3answers
Hi..greetings to all kind technicians here..kindly help me for my MSI U135 mini laptop..i can't connect to my wireless signal..it said that my wirless is turned off but i already install the...
I have a brand new MSI wind u135 nbook which runs windows 7 starter, and for some reason the web pages either load very slowly or not at all. This goes for both IE and Firefox. The connection is good and...
This is probably a RAM issue concerning windows 7 program usage open your task manager (ctrl alt delete and click task manager) and see how much RAM both the internet and other programs you have up take.
15helpful
2answers
Ive got a msi U135 with built in web cam how do i switch it on?
Computers & Internet Logo
Ekse
