Question about Moen & One Handle Tub & Shower Faucet
What's your problem? why did putting new stem cartridge in moen single handle tub &shower faucet reverse hot & cold water
After installing stem cartridge the hot and cold water changed sides why
Posted by eugene_misun on
michael liloia
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
Remove and turn cartridge 180 degrees then re-install
Posted on Mar 24, 2013
Moen single handle tub/shower valve . No hot water, cold OK. Nearby shower same vlave works fine. Cartridge "looks" OK. What next,
Even if the cartridge looks good from the outside I have had them plug up internally with mineral deposits. I would remove cartridge and replace it.Hope this helps.Thank you
Mar 28, 2011 | Moen & One Handle Tub & Shower Faucet
My Moens One handle tub shower shot out at me and i could not stop the water for nothing what would make it shot out
If it is an older valve there is a small copper retaining clip that holds the cartridge in place. If this clip broke it could blow cartridge out or come out when you pulled it to turn it on.
If that is the trouble you can see the slot in the top of the valve body where the retaining clip goes.You will need to get a new clip and put the cartridge back in and insert clip to hold it. If you find that you have the hot and cold sides reversed simply turn the stem of the cartridge 180 degrees and you should be in business. Thank you
Jan 02, 2011 | Moen & One Handle Tub & Shower Faucet
We recently installed a Moen single handle faucet in a refinished shower after having a plumber replumb the front of our house. Handle appears to be properly installed. Now there is no hot water or even...
u need to adjust the scald protector all single handle units are shipped in cold position for safety reasons if have paper work for handle it explains how to adjust if not unscrew handle and remove on handle / valve stem will see a red and a blue plastic clips pull back clips and turn slightly and push back do this till desired hot and cold setting are to your liking replace handle and your done
Dec 17, 2010 | Moen & One Handle Tub & Shower Faucet
HOT AND COLD REVERSED MOEN & ONE HANDLE TUB
This is a very simple fix. NOTE: This is for a Posi-temp model only!! First turn off the house water. Relieve the water pressure at a nearby sink. Then remove the handle from the faucet. Remove the black plastic piece, then the two white plastic pieces (these control how hot the water gets by controlling how far the handle turns), then the metal cover over the center piece of the valve. Once these are out of the way, there is a small metal clip that you can see that holds the cartridge in place sitting in a **** on the top of the center piece. Remove this carefully with a small straight edge screwdriver, taking care not to lose it. Then with a small pair of pliers, pulling on the center of the cartridge, pull straight out. Once the cartridge is completely out, turn it counter clock wise, 180 degrees and then reverse the process. The hot/cold will be in proper location now.
Now for an older style, simply take the handle off, turn the center portion of the cartridge 180 degrees counter clock wise and return the handle. Hot/cold will now be in their proper locations.
Good luck.
Aug 26, 2010 | Moen & One Handle Tub & Shower Faucet
Replaced trim ring and handle, now hot is cold ,cold is hot
Remove the handle and turn the stem of the cartridge 180 degrees then put your handle back on.
Apr 27, 2010 | Moen & One Handle Tub & Shower Faucet
Have no Cold water coming out of shower/tub. Replaced the Moen cartridge and still, no cold water. When knob is turned right I get hot water when turned left I get a trickle of hot water.?????
Hello
Take the plastic knob off.Turn the brass stem with a pair of pliers until you get it in the proper position.
Off faces down
Cold faces left
Hot faces right
Once in the position screw pastic knob back on.
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
The moen began to leak over time now i cant turn the water for
Call moen and give them your model no. they will send you a new cartridge free of charge. if you can't wait local stores like lowes will have them. Turn off your main water shut off valve and take off handle, then with some pliers take off brass ring, the cartridge will pull out. First notice the notch it rests in and notice where the hot water adjustment disc is. Assemble the new one the same way, put some vasolene on orings and reassemble. hope this helps.
Jan 12, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Moen kitchen faucet. I changed the cartridge but
Single or dual lever? A new ball if single lever. Home Depot or Menards will carry them. Teflon tape if dual cartridge. Stay away from moving parts
Aug 14, 2009 | Moen & One Handle Tub & Shower Faucet
Hot and cold backwards on a moen shower faucet
tun off the water.
unscrew teh allen screw under neath the handle. pull out hteh handle. undo the wall plate and gain access to the cartridge in the handle body. turn the artridge around 180 degree and reisntall all parts.
Apr 06, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Only hot water, no cold water.
The cartridges in the single handle units are prone to display this issue in hard water areas as mineral deposits such as calcium build up on the stem. The stems also have small rubber band like rings - for lack of a better term- that break apart and can clog the ports on the side where the are on. New stem should resolve the issue totally unless you have had a pipe break or other construction to the plumbing system recently. Thanks for using Fix Ya.
Mar 01, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen & One Handle Tub & Shower Faucet  Logo
635 people viewed this question
Top Moen Home Experts
Mike
john h
Bruce Robin
Are you a Moen Home Expert? Answer questions, earn points and help others
